277 -
12
Posts posted by Pintogogo
Has anyone got a complete spare sierra brake servo pipe for sale
cheers
Harry
cheers
Harry
Have a rake through forums, there are a couple of really goo wiring diagrams for column switches, I used them to do mine no probs
Now sorted....... turned out to be faulty push start switch in gear knob ..... new circuit from ignition switch to starter solenoid through 4 pin relay just the job
New battery, fully charged, when i left ignition on and put jump lead from +ve side of battery to +ve feed to solenoid and car turned over and fired up
Car all ready for MOT ..... and it wont turn over, just a loud 'click' from solenoid, all connections & earths checked and OK, so time for a replacement..... but struggling to get correct unit, it appears as though there are 5 variants for the 2L and I'm struggling to get correct one (Lucas), now awaiting 'special order' delivery from europarts
See you all the 26th
Harry
Hi sorry its my fat fingers late at night, other side of lamp should go to Ign switch +ve ....sorry
It should work
Try bigger wattage bulb in alternator feed wire temporary before stripping alternator off, I had same problem with ignition on - blue thin wire to alternator is +ve to one terminal of warning light and other terminal of warning light is to -ve, when the engine starts and alternator running the bulb 'excites' the alternator and the blue wire changes to -ve ,hence the light goes out, if the alternator belt snaps etc the alternator stops charging and the blue wire returns to a +ve condition illuminating ignition light, sounds complicated but really easy if you break it down
I put a number plate lamp under bonnet in parallel with ignition light to excite alternator
Hi Alan
I've just sourced bushes & clamp for anti roll bar mod so I've that to do and fit my new wings then I'm ready, just been slow cos of recent health probs but carbs fitted & sounds good, ill give you a shout when its back on road, cheers
Finally got my bike carbs on n running - bit of tuning n well be good to go
CBS supply different length drive boxes (spindles) that should give more clearance from your scuttle panel, I had same problem, 2 new drive boxes ( about £20 each) and problem sorted
That’s great thanks they will get me away
PM sent
I was really after the ones with the raised emboss in the middle but need to get on road how much are you after for those plus postage please
regards
harry
'Bit of a long shot' but I'm after a pair of front anti roll bar clamps to fit a Sierra 24mm roll bar, my clamps are flat across the section and I'm after a pair with centre ridge to fit poly bushes
Regards
Harry
Hope its a goer, Id be up for that Alan
Harry
https://www.burtonpower.com/breather-elbow-sohc-pinto-681f-x-flow-pre-x-flow-20mm-fp280.html
Hi Lewis
I have literally taken mine out yesterday and replaced it with a unit purchased from Burton (see link above) I removed old breather with a pair of pump pliers, rotating it back and forth whilst lifting and it came out no trouble, cleaned hole with cloth and burton aluminium breather pressed straight in with a gentle tap home with a nylon hammer
regards
Harry
Thanks Grim
I've ordered one of those
Harry
Hi
I'm after a Pinto engine crankcase breather valve (preferably without valve inside) so i can fit oil catch tank when I fit my bike carbs
cheers
Harry
lol no mate ill fit them when im feeling a bit better, hang on in there you seem to be winning battle with webbers
Still haven't got around to fitting your bike carbs yet Tony, hope it goes a bit smoother for me than the toil you've had with the twin webbers
Harry
there's some good wiring diagrams on here for sierra stalks, mini wiper motors to sierra stalks etc etc
North East Area Club Meeting June30th from 7-30pm
in Events
Ill be there.........I hope
