1,714 -
19
Posts posted by jaimo
God dean how big is your garage
Have you moved the car to settle the suspension
Can get away with slight amount of play but not alot remove cap if one remove nut then bearing pack some grease in then grease bearing and refit
Might have to pull drum off as bearing can be awkward to get out
if that type fitted obviously
If closer keith would of helped
You wonky keith never
Check inlet manifold gasket and the hoses as mine was similar when fitted
Also if got vac port on manifold is it connected to servo or blocked as will also pull air there
Thats how my pinto sounded when sucking through bike carb manifold gasket due to injection head
Link not working
I have a 4-2-1 fitted but have aquired a 4-1 as 2nd pic of peters above but the down pipes have been slightly flattened to miss steering is it worth fitting in place or if sell whats it worth
Dont fit the lsd mark give it to me
seriously lsd all the way
No regulator its not needed as bike pump and a filter on pipe from tank before pump which is mounted in boot area
Also just been out for a spin and wow wot a difference must of been going for a while
Did this happen since rewire
Also i am led to believe cant fit a towbar unless qualifed due to insurance will be invalid
Sticking by the sounds of it just had that problew with my r1 pump works then seems to stops tap it and works ordered new pump
Trying to work out how it fits and operates
I have just had this with r1 carbs and r1 pump ordered new pump as not working enough
Yeah i too thought butresses and price
Spotted
in Chit chat
Maybe went on both as was on way back from minehead butlins
