168 -
Everything posted by wowblaauw
I managed to buy GBS Zero gt set by accident when mine is a standard Zero. Think they cost £14.95, tenner plus post and they’re yours unless someone is passing and can do the RHOCAR post thing Cheers Craig
Ok thanks, I’ll let you know, I just want to make sure that they will fit.
Finally, and I really mean finally. Just one thing though and given the original symptoms, I agree with all comments regarding the high tension circuit, that leads, coil pack etc. as mentioned I replaced the whole lot. Ok, so finally, it was the HP fuel filter. When running new fuel lines I replaced the filter (Sytec) and pump as well. I had (several weeks ago) replaced the new HP pump with the original I’d taken out but with still the same issue. This is the first spare weeekend for more than a month. So with my 3 month old baby we planned a complete strip of the fuel system and a rebuild. Late Friday during final stage she gurgled and I interpreted as change the filter. I had bought a new Epman from the bay and thought maybe I carry out a quick filter change first. While I was at it I checked the line from swirl pot to the filter, fuel ran freely, ok. Then changed the filter, tested for leaks, all good. Time to fire up. Wow, instant catch and running. Once warmed, checked the fuel pressure and brought back down to 3 bar and tested. All good so far, so with a final wave to the baby off I went on the test. Well, I couldn’t believe the change! Christ I thought, I better slow down, responsibilities etc. A 10 minute test became two tanks of fuel and a frustrated mummy; daddy not doing his chores... So finally, all the issues fixed and on the 10th month anniversary from the day I started to strip the car. What a journey. The ups and downs, guess it’s all part of the fun eh! Thank you all for all of your comments and help, very much appreciated. What next? Handling! With all this new power, talk about bump steer, skittish handling, no confidence in turning in, bouncing all over the place... Cheers, Craig
Hi, do you have dimensions?
Coolex Alloy Polo Derived Radiator And Spal Fan
wowblaauw replied to speedtripledan's topic in For sale
Pm sent -
Ok, here’s what I’ve figured. When I had the car up on its stands last year to re-run the new electrics I also decided to replace the cooling and re-run some of the fuel lines. Cooling is now very happy. Fuelling however is not. Before I start with where I am I did replace the ht leads, plugs and coil pack but without change. The original builder ran a mixture of copper piping (all the same sizes) with rubber hose and 90* bends which didn’t look the best and was corroding so I changed from the swirl pot to fuel rail with a new bullet filter and HP pump with what I thought was an-6 lines. Actually it turns out that I was supplied an-8 pipe which I fitted with an adjustable regulator. At first when I discovered the misfire under load it was due to not enough pressure - slight misread on the gauge by me. Then when running the car I now get a lack of power- I mean don’t get me wrong the Car does go, just not that quickly for around 4 miles and then misfires until it stops. I leave it off for a bit and it then fires up and off I go again. I’m probably answering my own question here but do you reckon it’s because of a pressure drop or starvation or account of the change in line sizes? Oh, the HP pump sounds like it wants to take off due to the noise it’s making. I have changed the pump but not the filter. Ideas on this would be gratefully received. Thanks in advance, Craig
Hi All, just a quick updat; received spare pins from GBS last week and following the instructions as detailed above managed to replace the affected ignition switch pin and we now have a running motor again. Mot take two coming at the weekend. Thanks again everyone for all of your help and advise, very much appreciated. Cheers Craig
Many thanks all, and again special thanks to knights_tmplar et al. You are right, the car did run fine previously - I was warned, several issues waiting for the opportune moment to fail, notably the ECU - fluid damage and a misfire to pot 3 and a partial corrupt map caused havoc. Once past all of these it seems now that a cheap Chinese adjustable fuel pressure reg has caused some miss readings and following a hike in fuel pressure the misfire under load disappeared. I'll be replacing this with a new part soon. Another lesson to learn and I preach it almost daily - "you only get what you pay for". Thanks again fellas, all very much appreciated.
All, thank you very much for all of your input. I managed to get some spare pins and will be attempting to replace the faulty pin next week - trials of new baby and work life balance...Thanks in particular to Knights_Templar and mcramsay - used to date a mcramsey back in the day. Am sure it isn't you.
All, some of you will know my electrical woes are some 8 months old. Briefly I decided to replace the home made electrical system in my Zero last winter and ordered brand new gbs chassis and engine looms at great expense. After making some school boy errors with earthing etc I got onto cranking the engine. Here is where my 6 months of frustration started and ended today with having the car collected and brought back on the back of a truck. After fitting the loom 3 times and removing it three times I decided to run the loom outside of the car to find out why the ecu wasn't switching the ignition circuit. It seems that the ecu pin 4 (emerald k3) wasn't making contact with the engine loom block connector. Despite mentioning it to gbs several times gbs insisted on saying that there was nothing wrong with their looms and had never had a failure. Well they have now. Following a sort of fix with a bent ecu pin to make the connection I drove the car 20 miles to Sheffield today and all was well until it failed. Got it home and despite my many efforts to make this coonection work I can't. Seems though the block connector will not engage with the ignition pin 4. What I'm after is has anybody else had issue with their gbs loom in this way and what was th fix if any? As before I will be extremely grateful for any help. Thanks in advance, Craig
All, apologies for not getting back to you sooner and thank you all for your advice etc. It would seem that I have an issue with the new fuel lines I ran over the winter. I jacked up the fuel pressure and settled on 4.4 bar and the misfire disappeared. I'll be stripping out the new lines in a couple of weeks and will run an airline through them - have to fix the compressor first. Engine dies under load would you believe, seems the cap is failing, new one ordered so waiting for it to arrive. Will update you all soon. That said I have a new issue, see my new post, beers, Craig
All, as a quick follow-on, with respect to knights_templar's post. He is quite right I have had loads of issues following a major upgrade over the winter which has dragged on for some months now, being beset by issues mostly created by my good self I must say - age, experience... Anyhow, it would appear that I am getting to the end game. Following another weekend of garage torture I found that the misfire under load was due to fuel pressure. At 3 bar it misfires and at 4.4 bar is perfect. Any thoughts on why this is would be will of course be gratefully received. My map is tuned for 3bar with injectors of 300cc. (Map supplied by GBS to get the engine going ahead of RR) My injectors are standard Ford 200cc - would this be the cause, a mismatch between injector and map? or am I barking again... I've also dropped an email to the good people at Emerald and hope to have a response later on a more suitable map. I would however like to thank you all for your input.
All, thank you so much for your responses. Ok, coil pack replaced with (admittedly not known working) HT leads with the same result. Engine fired and runs very smoothly. Got it to 60d and applied throttle only to get an almost stall a few back fires and the rough revs. Logic tells me that if this coil pack and leads were good then I would get the same results but doubt it would have the exactly the same fault? Spark plugs are new - same result TPS is new and not over tightened Just one thing though; the engine loom to ECU had an issue with not firing the ignition circuit. While I realise this may be a long shot, is there anything in this. The issue was with connection from pin 4 to loom block not making a good connection. A bent pin later and I had a spark and where I am today. Checking earths now
Thank you chaps, much food for thought especially as I have a whole weekend (1st in many moons) to look closer at the issue. I have a spare coil pack and HT leads, spare plugs so will give it all another go. I especially wondered about the lack of flow so have already replaced the injectors. The MAF sensor is new from Emerald so am thinking I can check that off the list. As for the Lamda I haven't set the car up with this type of sensor.. yet. One of my future tasks. I will upload my finds come Sunday evening. If I can identify what the issue is then its off to the rolling road. Thanks again for all of your help, sometimes its good to hear it from others who have had similar/same experiences. Craig
Wow, thank you so much. The map is the GBS TB powermap for 2.0l Zetec. When it comes to the mapping side I have absolutely no idea as I kind of missed all of this during a time when all I did was buy and drive.Trying to play catchup later in life is like trying to teach an old dog new tricks... TPS is wired correctly as per GBS instruction - as for 'ecu not seeing the change correctly' may well be the issue or not. Like I said, I am not up to speed when it comes to the mapping side of the engine management. TPS has been reset several times as I balanced the throttle bodies and now is set and balanced nicely. Just missing under load.
Hi chaps, I have a Zetec 2.0 crate engine with 1000 miles on it. Last year I added AT iTB's and although I had a misfire at the time it seemed to sort it self out as the engine warmed up so I paid scant attention to it. However, since I started the big strip and rebuild; replaced the entire electrical system, new engine and chassis looms, a new dash board, dials etc, switches et al cooling system, fuel lines, pump filters all with new product I/we have developed a much more serious misfire under load. Since I started this big upgrade, I found that my Emerald K3 had some fluid ingress and was misfiring on 3 which was highlighted by the good folk at emerald and repaired I still however have a misfire under load. The engine will crank, fire and run at low revs very nicely but as soon as the throttle pedal is applied I get a cough splutter, lots of misfiring back through the air filter the odd back fire and generally no power unless applied slowly. Any ideas? Thus far I have replaced the manifold 'O' rings, the HT leads, coil pack and plugs (head and brain), think thats it for now, any suggestions would be gratefully received. Thanks, Craig
Message sent
Hi and thanks for the responses. The map was used for the past 500 miles ahead of the loom replacement. Thee only thing that's changed is the loom. Currently I have made adjustments to the loom and ran this morning ok. I'm just thinking ahead as a just in case gbs say no to replacing the loom. If that is the case, then I'll make a more permanent mod to the existing wiring or preferably a change to the map injector configuration.
Eureka! I was measuring outputs from the ecu to injectors and then matched to the map driving the ecu and here's what I found Cyclinder 1 injector - correct Cylinder 2 injector is cyclinder 4 Cylinder 3 injector is cylinder 2 Cylinder 4 injector is cylinder 3 My next question is this; any ideas on how to change the injector sequence in the ecu - why because my engine loom now resembles something of Heath Robinson affair. Thanks again in advance Craig
Update, the issue is with the block to ecu connector with the engine loom. One problem solved by bending pin 4 on ecu to make better contact with connector. Did try closing the connector female pins but couldn't make the connection reliable. My only worry here is one of reliability. Anyhow one problem solved leaving the misfire. I have a misfire on cylinders 3 and 4. I removed the manifold cleaned all surfaces and fitted new jenvey O rings. No change. I've replaced the ht leads, coil pack and plugs - no change. I had a spare set of injectors kicking around so changed these but without change. Any ideas would be gratefully received. The map I'm using was supplied by GBS and was running successfully before I changed the looms. Thanks, craig
After spending nigh on £900 on the factory loom (engine and chassis) - its predecessor was a bit of a birds nest so in my constant search for perfection I went the way of the GBS P&P loom - I am reluctant to throw it out and start again. That said, I wired the dash from scratch which was simple enough - just a case of following the routes. I have dash switches rather than stalks. I don't have an issue with electrical work per se but this loom is an absolute nightmare. I have no schematic and to be honest I was hoping that someone else may have had the same experience and was willing to share not that I would want this on anyone else... The loom is definitely coming back out tomorrow and will be on the bench ready for my meter. I am determined to find out why this loom is functioning the way it is and my wish is to make others aware that this may be the case despite what GBS say. Anyhow, I'll get back to you when I have this apart with a level of understanding so I can share it. Cheers, Craig
HI Richy, seems you got a post in just before my last response. When I switch on, fuel pumps start, ECU LED goes red and when I crank the ECU goes green as it should. I do have a decent earth (one of my many mistakes), and having rechecked several times am happy with the way the loom has been run. When I asked a local pro to come and help he started at the misfire to number three cylinder worked backwards and found that the ECU was missing on this pot. He also stated that the ECU was not switching. However having sent the ECU off to Emerald they concluded that the ECU was missing on three but there was no fault with switching the ignition feed relay. We did bypass this and earthed the ground pin on the ignition relay which did bring the engine back to life only to misfire on three. I played with this for a bit and sent the ECU back to Emerald who after much coercion on my behalf re-ran all of the tests again only to find that the ECU is good to go. I also put a new map and Emerald informed me that they updated the firmware. I haven't as yet checked the output from pin 11 and 28 - which I will do this weekend ahead of stripping out the loom. If the readings are anything but what is expected then the loom comes out. That said, I now do not have an ignition feed even with the bypass - this is becoming really strange even (I think) my alternator has failed again. If it has it would be the third time the reg has popped - anyone with experience on failing alternators? The ignition feed comes directly from the loom's fuse/relay block and as such and because this is a purpose made loom with no schematic I am rather in the dark with it which is why I think removal and a strip of the fuse relay box is in order. Like I said in my last I was rather hoping someone else had a similar issue which I could work with and circumvent this additional work. However, I am 7 months in with this loom. No pain no gain. Thanks again, the hep is very much appreciated. Craig
All, many thanks for your replies - also, please accept my sincerest apologies for my miss post - fit of exasperation and frustration and wasn't watching what I was doing... Ok, engine is a crate engine with 1k miles on it - haven't checked compression yet. The inlet manifold has been checked and reseated just in case with new seals. New plugs, coil pack and HT leads have been fitted. Not much else to say other than I have this issue between the engine, loom and the ECU. Having spent some time with Dave Walker at Emerald we have come to the conclusion that this is a loom issue and as such my next task is to de-instal the loom out of the car and strip the fuse relay box down to check see what is going on with connectivity etc. I was rather hoping someone else had had this issue... Thanks again Craig
All, my first post on these here parts - that said, I have found most of the issues with my Zero were answered by the good people on previous posts on the RHOCAR. So here I am a newbie although I've been a member for the past couple of years asking for some good old fashioned help - apologies for the longwinded first post. I purchased a built Zero with many issues from a misfire to electrical problems from a home made loom and as such I wanted (before buying a new kit) test my skills before taking the plunge. So, the loom; I purchased a new GBS P&P loom at the end of last year and fitted while taking out the old home made job - in fact an almost complete strip, a new cooling system, etc and other jobs along the way. So, once the new engine bay and main loom were in these are the faults I came across. First issue bad earths - oops, since rectified and sorted Second issue, alternator regulator blown - out, repaired and sorted and installed Third issue, no oil pressure - replaced sender and hey presto Fourth issue, no water temperature, sender replaced and sorted Fifth issue, the ECU not switching the ignition circuit - ECU sent to Emerald and... Sixth issue, misfire on three - ECU sent to Emerald and misfire detected and repaired, no fault found on the switch for the ignition circuit Seventh issue, failed alternator - again? sent off and repaired Eight issue, ECU back and no change, sent back - Emerald kindly too a video showing the ECU fully functional Ninth issue, Alternator failed again, I think, no ignition light on on dash - and the ECU still not switching and a misfire to three and fourth not firing at all - before the alternator failed again I had the engine running post replacing the spark plugs with new, the HT leads with new and the coil pack with new. No change, still missing on three and nothing on four. I guess what I am asking for is some sanity. I have Emerald saying that the ECU is fine Having replaced just about everything electrical I still have some fundamental issues GBS say that their looms are fully tested before leaving the factory and therefore cannot be at fault Any advice is good advice, but if someone could lend me a hand here I would be eternally grateful. Thanks in advance, Craig
