IanS
Posts posted by IanS
  1. I think that the reasoning goes like this.
    There is a mirror behind each bulb that focuses the light to some extent. This focused light should be aimed straight back to increase the distance that the light is obvious.
    So my take is that the original light cluster needs to be vertical.
    Production car rear light clusters internally make sure that this is achieved even though they appear to be sloped.
  2. Sorry I should not have put in the second comment and apologise for it.
    I also have the same problem and a new mechanical pump made no difference to the starting, it was still grind grind to fill the carb so I do not think that a non return valve will help.
    I have had problems in the past with the reliability of aftermarket electric pumps so I have both. I use the electric to prime the system and the mechanical pump when running.
    The electric pump has a simple push button mounted out of the way, I push it untill the noise from the pump changes and then start.
  3. The S3 never had a build manual. It came with a couple of VHS tapes that showed most of the build. They are a bit amateur but show the tricky bits.
    I believe that they are available on Utube.
  4. Sorry but that is a confusing diagram.
    Thermostat in radiator return line, I have never seen that and wonder how it can work.
    The thermostat is normally closed and opens as it warms. It is always near engine in the line taking coolant from the engine to the radiator so as to sense when the engine reaches operating temp.
  5. This is normal. Belt finds its own position on the toothed wheels.
    There are 2 guide washers to prevent it falling off. 1 behind the top wheel as shown in your bottom picture and one in front of the crankshaft wheel. Between the 2 washers the belf cannot fall off. It is normal to lightly touch one or the other.
    In the top picture there is braided cable / hose that looks very close to the belt.
  6. It is possible to remove the engine and gearbox together.
    The nose cone and radiator will have to be removed to do this.
    After disconnecting gear lever, speedo drive, reverse light switch electrical connection, clutch cable disconnected and gear box rear mounting the gear box is free.
    The engine needs all electical connections disconnected, fuel pipes removed, exhause manifold removed and heater pipes removed.
    The engine mounts can then be unbolted and with the engine suspended from a suitable crane/hoist it can be lifted clear of the mounts and pulled forward to release the prop shaft, it will result in a bang as the prop shaft drops, tilting the gearbox down it is possible to move the assembly forward and up.
    This will most probably result in a large loss of oil out of the rear of the gearbox.
    Otherwise the engine and gearbox can be split in the car by supporting the bell housing on a jack and pulling the engine forward to disenguage the gearbox input shaft befor lifting the engine out on its own.
    The gearbox can then be removed level without spilling oil.
    Refitting the gearbox I have disconnected the porpshaft and pulled it forward in the transmission tunnel far enough to easily push the shaft into the gear box before pushing the gearbox back onto its rear mounting and supporting the bell housing at a height to allow the engine to be wiggled onto the input shaft and the bell housing bolted back up.
    Then reconnect everything.
    Good look.
  7. It has been done many times.
    How depends if you want the wings to turn with the wheels or just be fixed straight ahead.
    I do not recall any one doing what I would call a good job of stearing ones. Others may differ.
    Some cropping of the suspension tops and judicious cuts to the fiberglass have given a reasonable result to fixed straight ahead wings. This should pass MOT as most production cars have parts of thier wheels out in the open at full lock.
    Sorry no pictures.
    • Thanks 1
  8. I agree and have always set the cam by measuring movement of number 1 inlet valve.
    The pinto has unusual cam to valve geometery as the followers rock on pillers set to the side resulting in changing timeing when lift is changed. This is a complex situation but the cma manufactured will have known about.
  9. If you have 21W normal oldfashoned bulbs then the nominal currant is just under 2 amps with an inrush of 4 to 6 amps (cold filamant high current, as filament heats to near white heat current drops as resistance rises). 50% duty cycle so any wire 1 to 5 sq mm.
    LED bulbs have lower current and inrush is not a problem and the above wire is overkill but robust and easily available.
