2,374 -
6
Posts posted by stevedohc2b
Right Nigel test is all ok
had the battery tested all ok
checked continuity all good.
On cranking the battery volts drop to 10.5 volts
have made a hot lead for ignition live feed and clamped to battery the dash battery light won't light till this is connected ?
gave it a good rev and battery light went out drop revs Bach on and no volt increase at battery.
Stephen
( Usefull tip is to remove the exciter lead from the alternator, extend it with a flying lead, ignition on. The ignition light should be off. Touch the end of the flying lead to the battery neg. Light on. Touch the end of the flying lead to the battery pos. Light off. No smoke at any time. Shows it's working as intended.)
Nigel do you mean the warning light not the ignition live exciter lead.
stephen
Hi
i have a zetec with a small denso type alternator and broke down the other week with no charge going to battery.
fitted a new alternator seamed to solve the problem then after a 2 mile test drive the volts dropped down to 12 and no charge to the battery.
I had added some led driving lights before this happened and put MOT miles on before i broke down on a 100 mile run
Took off and had both bench rig tested and no output. So fitted a new reg removed led lights feed,too no 2 and still no joy.
how can i further bench test
i have diode tested the rectifier in place and only reads one way
help may be in the tin top at w/e
Stephen
Hi Bob
Can we have a place please
Stephen & Lesley
I found out how far you can drive on a battery when alternator gave in. I have a volt gauge that while driving through Blackwall tunnel went down to below scale, made it through but only had 9 volts at battery with a test meter at terminals car still running gave up 10 miles on so made about 15 miles with side lights on as well.
so both are a help new one fitted and now get a good 14 volts.
Stephen
Have a good one Nigel
Stephen
Yes well worth doing did it in 2009 with ian and frends
not for faint harted as as your own risks.
Some pics on my photo bucket link below
http://s119.photobucket.com/user/stevedohc2b/library/Ring%20trip?sort=4&page=1
Stephen
Have used a ultra sonic bath length of pipe a 5 volt supply with injector cleaner on sons old saxo works well but had 4 Spair from scrap yard
Looks great
great talent
will dig out a pic
Stephen
Sad day Steve hope you enjoy retirement
But now you will have the time to use the Hood !!
Great times had with you and the car facing wrong way around the ring and in pits at Lemans
Stephen
2 please Bob a Silva
Could make it a late birthday is well
not far off 15th
Stephen & Lesley
All the best for 2016
I have 2 visits planned to the dentist as broke a filling week before Christmas so not looking forward to an hour in the chair each visit
and a big bill.
Stephen & Lesley
Hi
I lost my Dad last year and when a child we used to make these paper stars at Christmas.
So found these instructions on the Web on how to make so thought I would share
http://www.highhopes.com/3dstar.html
Great for the Tree.
Stephen
Yes general under bonnet heat is enof bob simple thing first. Second for cable change.
Stephen
What engine is it pinto / twin cam
My local factors has some as OEM quality Allparts automotive http://www.allpartsautomotive.co.uk/contact-us/our-branches/
Ford a or a scrap yard
I also have a a ford beakers near work SE18 All ford
All FordsGarageAddress: 61-68 Eastmoor St, London SE7 8LXPhone:020 3556 0824Stephen
BOB might be of help http://www.auto-tat.co.uk/Escort%20Upgrades/Chapters/Engine/CVH/Breather%20System.htm
stephen
Bob did you check compression
first?
Stephen
Do you still have the heated rear screen
Stephen
- 2
Bob
I have a gusson tester had to get an adapter to fit plugs in zetic
Your local garage should have one.
Not expensive to by under £20 on each bay
so would cost same to post you mine.
Stephen
from haynes
2.0 litre DOHC fuel injection models
A development of the EEC IV system is
used to control both the ignition and fuel
injection systems. The module receives
information from a crankshaft speed/position
sensor (similar to that described for the ESC
Hybrid system), except that the sensor is
activated by a toothed disc on the rear of the
crankshaft, inside the cylinder block), a
throttle position sensor, an engine coolant
temperature sensor, a fuel temperature
sensor, an air charge temperature sensor, a
manifold absolute pressure (MAP) sensor, and
a vehicle speed sensor (mounted on the
gearbox). Additionally, on models with a
catalytic converter, an additional input is
supplied to the EEC IV module from an
exhaust gas oxygen (HEGO) sensor. On
models with automatic transmission,
additional sensors are fitted to the
transmission, to inform the EEC IV module
when the transmission is in neutral, and when
the kickdown is being operated.
The module provides outputs to control the
fuel pump, fuel injectors, idle speed, ignition
system and automatic transmission.
Additionally, on models with air conditioning,
the EEC IV module disengages the air
conditioning compressor clutch when starting
the engine, and when the engine is suddenly
accelerated. On models fitted with a catalytic
converter, the EEC IV module also controls
the carbon canister-purge solenoid valve.
Using the inputs from the various sensors,
the EEC IV module computes the optimum
ignition advance, and fuel injector pulse
duration to suit the prevailing engine
conditions. A “limited operation strategy” (LOS)
means that the vehicle is still driveable, albeit at
reduced power and efficiency, in the event of a
failure in the module or one of its sensors.
1.6 litre and 1.8 litre (R6A type) CVH models
injection systems. A fully electronic
Distributorless Ignition System (DIS) is fitted,
replacing the mechanical distribution of high
tension voltage (by a rotating distributor) with
“static” solid-state electronic components.
The system selects the most appropriate
ignition advance setting for the prevailing
engine operating conditions from a threedimensional
map of values stored in the EEC
IV control module memory. The module
selects the appropriate advance value
according to information supplied on engine
load, speed, and operating temperature from
various sensors.
The EEC IV module receives information
from a crankshaft speed/position sensor
(similar to that described for the ESC Hybrid
system), except that on 1.6 litre engines, the
sensor is activated by a toothed disc on the
flywheel), a throttle position sensor, an engine
coolant temperature sensor, an air charge
temperature sensor, a manifold absolute
pressure (MAP) sensor, a vehicle speed
sensor (mounted on the gearbox), and an
exhaust gas oxygen sensor.
fuel pump, fuel injector, throttle valve control
motor, pulse-air control solenoid, carbon
canister purge solenoid (where applicable),
and the ignition system.
ignition advance and fuel injector pulse duration
to suit the prevailing engine conditions. A
“limited operation strategy” (LOS) means that
the vehicle will still be driveable, albeit at
a failure in the module or one of its sensors.
Precautions
General
It is necessary to take extra care when
working on the electrical system to avoid
damage to semi-conductor devices (diodes
and transistors), and to avoid the risk of
personal injury. In addition to the precautions
given in the “Safety first!” Section at the
beginning of this manual, take note of the
following points when working on the system.
Always remove rings, watches, etc before
working on the electrical system. Even with
the battery disconnected, capacitive
discharge could occur if a component live
terminal is earthed through a metal object.
This could cause a shock or nasty burn.
Do not reverse the battery connections.
Components such as the alternator or any
other having semi-conductor circuitry could
be irreparably damaged.
If the engine is being started using jump
leads and a slave battery, connect the
batteries positive to positive and negative to
negative. This also applies when connecting a
battery charger.
5•4 Engine electrical systemsstephen
Alternator Problems
in Electrics
Stephen
