2,374 -
6
Posts posted by stevedohc2b
The only porker was the hog roast Sunday.
Stephen
Greater weekend thanks Steve for the Curry Saturday. I can feel the sun burn still on my face...
Thanks for the great company and efforts by the committee and all the other helpers.
Stephen
- 2
8 pints of soup made ready and it's HOT
Stephen
Will sell both
Car £6000
Built By Owner
SVA Oct 2003
New crate Zetec 2009
140BHP on rollers
Omex 600ECU
Profesenal Engine Loom
New Dials 2011
Leather seats
Stainless Chassis
Avo Coilovers x4
Built with New Brakes
New starter 2009
New Alternator 2009
Rear disc Brakes
Reco MT75 Gearbox 2009
Led rear lights new 2014
Wipac Quadoptic H4 Halogen Head lights 50W Spot lights
Lamanted Windscreen 2014
MOT Oct 2015
Quick fit Surrey Roof
Travel europe with ease
Just make sure you don't mix your Babycham with too much Tom Yum Stephen!
No pear cider this trip I hope Bob brings the grouse .
Stephen
Might make at home and re heat
thanks Al
Stephen
I am going to make a big pot of Tom yum soup as a supper warm up
Nigella Quote
" The culinary equivalent of Friar's Balsam - clears the tubes and brings fire to the jaded soul. And there's nothing like a bit of searing heat to push away any hungover seediness. It's good for those days when you're thick with cold, too."
Stephen
The size of the piston is bigger on the abs ones rest is same.
Stephen
First pic look's a bit of a Dog.
I would still remove pipe from pump and blow air back in to tank and take sender out and have a look to check all is free, if the feed is from bottom any crud will settle at bottom and get sucked down pipe. I had a bit of a gasket get sucked up mine that is fed from top. i have a silver top pump. if then all ok replace cube cheap enof. i do carry a spare low pressure and high pressure pump as had both fail over time.
Stephen
It could be something blocking the pipe from the tank, a blob of sealer sucked up the pipe, easy check remove and blow through.
If flow from low presure pump is slow. Also check the return from fuel rail.
Stephen
cast not very nice for the weekend so I think it will be the old mill hotel we have booked instead of camping.
Steven is that a tear drop ??
yes its for sale
Stephen
Thats ok rain can run out as well as in.
Thimk postive
I went through one storm and floods and had gravel on the seats when we got out took ages to dry out
Stephen
Ken
Just drive faster and it blowes over the top :-)
wrap up warm as if on a bike you should be ok you will need at in evening as gets cold.
stephen
Richard
that looks very much like my intake but mine points to the front they did both types.
Looking again i think it is same as looks upside down in vice?
watching with interest
Stephen
a video review
Hi I have for sale my tear drop Caravan
A Turtle 1200 it is great to tow behind the hood only 400kg
It has big van features
- 12v on board power
- 240 volt mains hook up & 30m lead included
- 3 way fridge
- Led lighting
- 12v battery charger when on 240volt
- Sports alloy wheels
- Alco hitch and Alco jockey wheel.
- Curtains and door side storage pocket.
- Slide open windows
- 2 side acess doors with above windows
- Wind up roof vent, with fly net and blackout screen.
- Kitchen with Fridge gas Cooker
- Porta potty Tollet with flush
- 25 lit water can
- solid Insulated construction.
- 240v power socket in kitchen and cabin
- 12v power socket in cabin to charge phones etc
- CD Radio player
- TV/FM amplifier
- Head board with wood insert. 3 Compartment storage behind. 12v socket and 240v mains socket.
- Shelving, Speakers, 240v Socket, Storage and Plug
- Main inside light and blue nightlight
- Outside light for awning
http://s119.photobuc...ideshow/Caravan
Can be viewed at stoneligh
£3500 ONO
TEL 07928 112354
Got home at 3 took the Hood out for a blat and a pint at a contry pub and 24 degrees. Hotter than baesolona at the weekend great.
Stephen
Terry can you plug in a laptop in to the ecu to see what is going on or running data login.
Could you try disconnecting the temp sensor for ecu when hot and prob happens or connect a spare sensor in to a cool water / air
To fool ecu thinking engine is cooler,
Stephen
Its the super charger giving off to much heat need to remove and sell on, bad design etc.
Get richard to fit a steam engine then you can have a brew at road side.
Stephen
- 3
We'll have some printed ones at stoneleigh for those that want them.
Just done 2000+ so some spar
stephen
- 2
In build a race car for £500 I am sure he used a lamppost or was that tricky in the Robin Hood videos.
Stephen
It is common to take the chassis number from the donor vehicle assuming sufficient original donor parts are used i.e. Engine, gearbox, rear axle.
No it is not that is known as ringing and carries poss of a stay at HMP ( the dvla issued mine )
Stephen
- 3
Stoneleigh Thanks To Everyone
in Events
Posted · Edited by stevedohc2b
Yes safe and well thanks just sun burn
I should change name to coco the clown !!
Stephen
