2,013 -
26
Posts posted by maccavvy
I need a plate making to fit my etb fuel sender into my tank.
Basically i need a round plate 90mm diameter with a concentric 40mm hole in the middle.
So basically looks like a doughtnut
Probably out of something like 2/3mm ally
Can anyone help out.
on what engine..
Research is the benefit here.
mine use the same pads as a range rover,which you can dealer buy at 55 quid. go to aston 250 quid ..for pads
Bet they stop your kit a treat.
heres mine ,in case you wanna look
To give you a clue on size the discs are 325mm diameter
i can buy one for 28 quid...i know i could knock one up. but if someone can lend me one., ill give em beer tokens and saves me money.
cant see me needing it in the future.
Ive got some sheet metal to fold at 90 degrees and have been looking at folders.
Before i buy one ,then sell it on as i only need it for a few small jobs.
Does anyone have one i could borrow in exchange for beer tokens or is selling one.
quoteline direct do one for 60 quid . covers uk and europe roadisde and recovery
That looks a snug fit...looks good though dude.
Makes my dash wiring look simple....have fun there dude.
Well finally got there today after a big job cancelled giving me the day off.
Ripped out the old escort clocks sat in the middle.Rewired new dash to multiplugs so easy to remove if needed
Got last few bits done. and got stuck in.
Looks like this now.
In case anyone wonders why everything is in the center,its down to the chassis tubes coming down either side.
doesnt leave much room for stuff.
Looks like mine is a leaded head.
looking to change to an unleaded one.
WHY and prices please.
Playstation went tits up last week. .... its under warranty they decided not to repair it and give me money to buy a new one.
Also booked a driving day .. end dates were wrong ...phoned them up and they added 3 months extra to take it in.
Needed new tyres for back of my BMW ..ordered off camskill turned up in 24hrs..top service.
No sorry dude. ive swapped that over to the new carb
http://www.ebay.co.uk/itm/110829187693?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
this is my old carb changed now so no need for it.
the engine is in standard tune dude.nothing special going on.
Fitted accuspark to my pinto engine.
it doesnt have a vacuum advance on the dizzy.
what should i set the timing to ??
advice appreciated. cheers guys
ive sorted the oil light..
not the battery light yet.so the battery light needs a live ign feed one side and then to alternator from other
cheers to mark for the info. easily sortable now oh and jez too as your right too
everything else works today after testing earlier
ill have a 38dgas for sale next week.
parrallel you say. between it and earth?
what size resistor do i need.
Just started today wiring the new dash set up in.
Got most of it working fine.
OIl pressure ,fuel gauge,water temp and all lighting fine
Not got rev counter fitted yet so dont know there yet
Indicator and main beam lights work fine.
But oil pressure lamp dont light up and battery light only comes on when its revved,when 1st fired up on tick over its out
The dash is all etb gauges with seperate round warning lamps,mwith all new senders.
Not checked the bulb in the oil yet as its too dark now but will tommorrow
Any ideas what to check 1st ?
depends which carb it is to how and where you adjust it
price sounds cheap...easy to swap too.
fit them and do an oil change at the same time imo
Wanted Custom Plate
in Wanted
Errrr oops
I type that fast i added another zero..
@ grim,i know i could use hole saws but i dont have the correct size.and never get a good finish on something round with a jig saw imo
@ shaft,cheers buddy that would be awesome .
