2,013 -
26
Posts posted by maccavvy
if you look at this pic.
http://www.rhocar.org/index.php?showtopic=31948&pid=240317&st=0entry240317
youll see the big washer. When the car is sat on the floor there will be a gap at the bottom of the strut where you can see the rod.this gap should be filled with rubber so that the suspension is damped when topping out.imagine it to be a bump stop for for other way around,thats how it was explained to me.
theres should be a rubber bush at the bottom,this can be made with big washers sandwiching some rubber.
Or get some anti vibration mounts off ebay that will want the center hole drilling out.,im buying new ones this week as one of mine is missing.
As for the spacer,get a big washer and file to shape.It should be angled slightly.
All info supplied to me by tazzzman after him giving my 2b sliding pillar the once over.
depends what your after i suppose.
Nuts and bolts are easy from local hardware style shop
for bushes check out ebay and type in anti vibration mounts.
Yeah got home fine....
thanks for giving it a once over and stopping my doing a 'mark b' ie losing a wheel
Ive sent you a link re missing bushes,gonna strip em down and sort em very soon and alter camber.
Thanks again dude for the info and help.
where abouts are you based dude. may help out.
Decided time to get the pony rear shocks off. Its got the oe twin coil things on that are soft as marshmallow
So before i go and buy new ones,just wondered if someone got any they wanna sell on and save me some money.
i need top mounts ,lower mounts and coilovers for a 2b
If not ill purchase new ,but thought id ask all the same.
imo it will be weeping fluid from the piston rod end.
so its just low and nothing else??
If you sit with it in gear and running with clutch down, does it creep at all??
Is it a hydraulic release bearing or a slave cylinder operating on an arm??
My van had a low biting point ,over 3 weeks it got lower and lower till i removed the box and found it was weeping fluid and letting air in.
Ill try to make it . but got osteopaths and unsure of appointment time.
Should be nicer weather to bring it too.
Fingers crossed.
worth getting weber one or aftermarket for a bit of a saving ???
After talking to many people saying my 38 dgas for my standard tuned engine could be a bit fuelly.Managed to drop on a cheap 32/36 dgav,but needs a rebuild kit to make sure its spot on before i fit it.
Best place to get one of these from. Local weber dealer ,ebay or anywhere else???
simple little duratec 4 pot lump.
Oil and filter, air filter,plugs and fuel filter should cover it.
all wheels off and check brakes for wear make sure nothing else is worn or leaking too.
tazzman seems to be the guru on sliding pillars. wishbones are good if youve got the money to change to them.
plus tazzman embarrassed a few wishbone people on race day with his pillar equipped 2b.
Finally sorted this issue......
Fitted an earth cable from battery to bell housing bolt..Water gauge works fine now. :yahoo:
No longer rises when driving.
Now ive disconnected it and fitted aftermarket this eve.along with an oil pressure gauge too
cheers for making me and the mrs feel welcome people, heres to more meets.
http://www.pistonheads.com/sales/3189794.htm
nothing to do with me. could be a bargain for someone though
ill be there in the bmw though..weather isnt good for a car with no roof .....if ya see some 6ft2 dude with glasses looking lost.
come say hello.
ill go have a look on the back of the clocks for somewhere to measure off.Cant see any road salt issues
If it increased with engine speed i could gather at voltage issues.
But it only goes up with road speed...
Least i know the engine isnt getting hot and the fan cuts in to cool it too,although it does sometimes come on when moving.
ordered a new aftermarket gauge anyway,including an oil pressure too.
Ill buy the rest over winter when i make a new dash.
update in my 'extra cooling?' post
Best place on the instruments to measure the voltage ??
i did exactly what mark said above with my mk5 stalk and washers.
live to motor,and wire from switch to pump earth, this goes to earth when presed..squirt. job done
Right guys heres an update
Fitted a new thermostat and new coolant a few days ago.
got hold of a temp probe,and today decided to sort it out
water temp at 18 degrees at standstill unstarted.
Started engine. rad water temp hardly moved for 5 mins,sat at tickover.
gauge started to climb then when gauge at 1/3 the rad temp rapidly rose,showing the thermostat opening.
Gauge then went to half way and after a few more mins. Fan cut in at approx 100 degrees
Gauge sat still, rad temp went down to approx 90,then fan stopped ,then temp rose to 100 again and fan cut in again. all the while the gauge sat still.
Got in it and went for a drive. soon as i started moving gauge went up to 3/4 and above, so i stopped popped the bonnet and checked the temp in the rad,never showed above 90, on the few times i stopped to check it.
I even coasted down a long hill ,so engine on tickover ,gauge still went high.
So it looks like a faulty gauge or sender, but it only shows a fault when moving.
think i may lose it for an after market gauge.best place to buy from??
also heat soak looks like its from a poorly sealed engine bay ..especially near my feet , think its time to bend some metal and sikaflex it in place..mild steel or stainless best.??
maybe of use to someone ,looks like a bargain to me.
I forgot to tell you marcus, terry has a temp reading thingy. Hoping for good weather for the meet Wednesday but its not looking like we are going to get a clear run
About the same time you posted this i was on my way home,swung by maplins and purchased a new multimeter with temp probe.
Only 20 quid and gonna try to put it through business.so all good.
May have a tinker before work in the morn...i dont do early starts see.
see if i can rule this out once and for all...btw with new stat and coolant in it runs hotter still...
Sliding Pillar Supension Help Needed
in Chassis
You may need the car built and on the floor to determine the best size for that bush.If you search ebay as mentioned you can find them for a couple of quid each.
not the easiest suspension to work with but tazzman seems to know his stuff and has explained it well to me.
Just got to sort some bits myself too.
