2,726 -
14
Posts posted by chris n
Congratulations to you both
Yep upwards and onwards!! the British people have spoken and given Westminster a swift kick where it hurts,
Just maybe they will start listening but I doubt it
One thing do we all get leavers hoody's like the school kids ????
Err nope!!! it should have been picked up at its last PMI and VOSA or DVSA as they are now known get there hands on it someone will
get there hand rapped.
New side rail needed or a plate welded in with a reinforcement box on the inside to put the strength back in
PM sent
Had a chat and the carbs are still available
I would go with a repair to, reinforce the back of the damage with some fibre glass matting, remove the rivets grind out the splits into
a V then fill using something like Upol SMC carbon fibre filler (which wont shrink back over time like good old P40)then skim over with a fine stopper then prime and paint as normal
I wouldn't try recutting splines back into the shaft, you could end up with a not perfect fitment and end up stripping the lot off
and have no steering at all..
If you can't find a direct replacement then try to find a local engineering company that can make one up for you
and cut the splines into a new shaft with the right tools or make a fully welded unit for you.
If you Google rs daytona replica there are a few photos
Or have a look at this-
https://replicars.wordpress.com/2012/09/16/ferrari-daytona-spyder-replica-by-richard-stewart-for-sale/HTH
You sure you have spliced into the right wire on the crank sensor loom and not the wasted spark side and its sending a signal
back to the coil pack.
Had a customer last year with a short in the loom plug going to the crank sensor and it blow the side with the plug on it off the coil
pack
That has crossed my mind Al
I use CBS for my electrical components whether its kit car related or not.
Always a quick turn round from order to delivery
Spent the other day trying to match a red on a bumper bar which turned into a hell of a job. What I needed was a sun gun which in layman terms is a very bright lamp that runs at full power at 3000 lux but at over £599 each and is a useful tool which we had at work when I worked in a bodyshop. I'm not going to rush out and get one anytime soon but I have heard of people in the trade make them out of an old cordless drill so thought I'd give it a go.
One old cheap 14,5 V drill with a burnt out motor which was bought in a supermarket sale about 10 years ago for about a fiver, stripped of its inners.
A quick mark up and rub down and a coat of primer, a bit of a custom paint job with any old base coat I had left over and a couple of
coats of clear.
A MR16 bulb holder soldered on to the wires that went on to the motor from the trigger and a 12v 40w bulb.
Body of the drill reassembled making sure not to go mad and over tighten the screws around the bulb so not to crack it!
plug the battery pack on and one working sun gun
All in all a couple of hours work in between jobs and a cost of under a tenner A good old hoody build
does what I need it to do and if I ever win the lottery I may get the proper one
No I wont will just retire instead
- 3
Try Lesley Storr Designs
very helpful
http://l-s-d.co.uk/ -
PM on its way
Only ever apply a very thin skim so that it only holds the gasket in place while assembly is taking place .
Never shove it on there like a ham fisted gorilla and it goes everywhere.
I always use Loctite red RVT on gaskets I'm fitting,
will seal valve covers, sumps, end seals, timing covers, water pumps and thermostat housings
Updated 25/04/16 (292)
Last update before Stoneleigh
BMW have two types of plug- standard OBD2 connector and a 20 pin round connector
Standard port is located blow the steering wheel near the clutch pedal...it is a small rectangular cover over
20 pin connector is in the engine bay, you will need an adaptor lead to make this work with an OBD2 scanner
All memberships are up to date as of today (16/03/2016) both on PayPal and cheque (post)
Next run will be done in the normal 21 welcome packs
updated 16/03/2016 (275)
End Of Season Bash, Best Yet
in Chit chat
Had a fab weekend with the RHOCaR family, Venue is spot on, band was great as normal and the
food van was ace - a must for the the next one.
Thanks to the committee for putting on this event
