Search the Community
Showing results for tags 'robin hood'.
  • Search By Tags
  • Search By Author
  • Committee Matters
  • RHOCaR - Information and Events
    • News
    • Events
    • Club Information
  • Construction
    • Chassis
    • Donor
    • Fitting & bodywork
    • Engine
    • Mechanics
    • Electrics
    • IVA
  • Adverts
    • For sale
    • Wanted
    • Other classifieds
  • Members Lounge (Access is via RHOCaR membership only)
    • Member Discounts
    • Loan shark
    • Build Threads
    • Build Blog Links
  • On the road issues
    • Maintenance & Modifications
    • Driving
  • General
    • Kit car related
    • Chit chat
    • Test area
  • Moderators
Categories
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
Website URL
Location
Interests
Car type
Full name
Found 8 results
  1. Hello, I thought I would let everyone know how I have got on with putting my Robin Hood through the IVA and to ask a few questions... My Robin Hood 2B was given to me by my kind friend part finished, I believe it was originally bought in 2002. It is based around a 1989 Sierra with a 2.0l Pinto with a 30/34 DFTH Weber carb. I have stripped it down and finished it over the last eighteen months and I am quite pleased with the result (or at least I was). Attempt one happened at the beginning of May and didn't go well at all. Prior to the test I had a garage down the road check it out and everything seemed ok apart from a bouncing fuel gauge. I didn't get the car back in time to sort the fuel gauge, so I just had to go for it. On the day of the test I filled it up at the petrol station in preparation for the fifty-mile journey from Blackpool to Chatterton. Fuel ended up leaking everywhere from the fuel sender and the car started running rough. Before I got too far from home, I just took it round the block where I broke down a few times as well as got pulled over by the police. I had all the relevant paper work so being pulled over wasn't an issue and I managed to limp the car home. Unfortunately, I couldn't make it to the test so £450 down the drain. Before my next attempt I serviced the carb, replaced the fuel lines, filter and fuel sender, fitted new spark plugs, leads and coil (from Accuspark) as well as checking the ignition timing and mixture. The timing was out, and I set it to about six degrees with the vacuum lines blocked as per the manual. There was also a leak on the line from the manifold to the servo which I fixed. Yesterday I set off nice and early for attempt two. Everything went well for the first twenty-five miles until I could feel the car needing more and more power to maintain speed. I pulled over and found that the brakes had come on and while I at the side of the road they came on completely. After looking around it I suspected that the servo was at fault either too hot, getting to much vacuum or faulty. I managed to get to the test centre (with frequent stops to keep checking) and on the way there the car started to run quite rough. It struggled to pull away and didn't like running at slow speed although it idles fine. Despite being late they completed the test and found the following... Metered Emissions - the HC reading was 4260 when the max is 1200. The car struggled to run at the required 2,000 rpm it just kept hunting between 1,000 and 3,000. The reading from the garage prior to attempt one was fine, well below the limit. I suspect I have messed up the mixture after the carb rebuild. Brake pipe or hose must not be exposed to excessive heat. The car has the original sierra manifold and the exhaust has a heat wrap around it. The servo is close to the engine and heat shield I made is obviously not up to the job (see picture, although the heat shield has been removed). I am thinking about removing the servo all together as described in other posts and then make a bigger heat shield. Brake warning light - The light on the dash functions with both the handbrake and the low brake fluid level switch. However, the low fluid switch doesn't seem to work. Am I correct in thinking that if I fix the low brake fluid switch and can prove it works by unscrewing the top that will pass? I can test the light from the driver’s seat using the handbrake or do I need a separate switch? A couple of sharp edges right under the dash that I missed. I have already put edging on them. The hand brake isn't working on the near side wheel. I will have to investigate. Brake lights are on all the time. I knocked the brake switch off while checking my brakes when stuck at the side of the road and have now fixed. Side repeaters are mounted on the body of the car and do not give the five degrees of visibility from the rear. I need to move them to the cycle wings. Headlight aim was out, I must have knocked them as they had been aligned by the garage. Fog lights come on with the side lights. I going to change the switch feed using diodes as described by other posts. Pinch nut on the from suspension was loose. The pinch bolt was tight, and I had put a safety bolt through to dummy strut but completely missed this. Stupid boy! Maybe unsurprisingly because of the brake issue they wouldn't let me drive it home and I had to shell out to be recovered to Blackpool . Yesterday was a very frustrating day to say the least! I have already fixed some of the issues and apart from the engine and the brakes my car is fine, ha! When I got home, I checked the spark plugs and they are black, so I guess it is running rich? I have a colourtune kit but I was struggling to use it, I will have to have another go. My dilemma now is how best to take it for the retest, do I risk driving it again? And, how am I best getting the engine tested/tuned without having the ability to drive it? Maybe I need to find someone with a trailer for the retest and a rolling road session? Graeme
  2. Check on preloved website http://www.preloved.co.uk/adverts/show/119139907/robin-hood-kitcar-track-day-car-with-car-trailerono.html?ref=advert-
  3. GCash
    Pinto Idle
    Hello I have just about finished my Robin Hood but there seems to be a problem with the idle. After a couple of minutes it starts going lumpy and cuts out. It keeps cutting out if I don't hold the throttle open slightly. It is a 2.0l Pinto with a Weber 30/34 DFTH. I noticed there is a pipe coming from the carb that looks like a breather (black and red). The problem stopped when I sealed the end of this pipe. This may be a stupid question but, does anyone know what it is for? Is it originally from the air cleaner? Thanks Graeme
  4. GCash
    Windscreen Marking
    Hello I am coming to the end of the build of my Robin Hood 2B and I am just in the process of fitting the windscreen. I have read numerous threads and the IVA manual and just want to confirm a couple of things. These are the markings on my windscreen... Am I correct in thinking that this won't get through the IVA because of the missing Roman numerals above the E? If I remove the windscreen, wipers, heater and washers and get it through the IVA would it be a bad idea to fit it anyway because it would be too dangerous? Thanks Graeme
  5. Hi, I bought an old 2b with sliding pillar partially built - 2 years ago. Lots and lots done, basically rebuilding the entire car, bit of an engineering project!! and we have just completed a GBS wishbone suspension rebuild on the front and replaced the damn awful pillar suspension! The car currently has a mg metro steering rack on that we have removed. I want to go to a ford rack to match the sierra track rod ends and extenders we now have. Would a mk2 escort match or what have other members fitted? Any help would be appreciated
  6. Guest
    Bone Fide Gbs Zero?
    Hi All, Uncertain and inexperienced new member asking for a quick bit of advice please! I have agreed to purchase this secondhand GBS Zero - please see expired eBay listing: https://www.ebay.co.uk/itm/122578482611 I've just checked on the DVLA website, however, as its registered as a Robin Hood. Questions: - Is this is genuine GBS Zero? Is there a way of checking or can you tell from the photos? - Assuming it is, does the slightly incorrect registration cause any issue/ concern? - Any other thoughts welcome! Due to exchange on Saturday so apologies to ask for a quick response... Many thanks all. Pete
  7. Guest
    A Few Pics (With Tunes)
    ... just a few pics with tunes ... enjoy! Admin Edit: Removed link to site that potentially shows spam and has a virus and replaced with direct link to the YouTube video
  8. Regrettably, time has come to part with my pride and joy. Not because I want to but because age has crept up behind me and I now no longer have the ability to get in and out. So here we go, Robin Hood Exmo Kit Car, Based on Ford Sierra with a 2.0 litre Ford Pinto engine mated to a 5 Speed manual transmission. It has covered 16643 miles since build. Purpose made plastic wind deflectors, Tonneau cover for every day use and full wet weather gear including side screens (not shown in photos) for when the British weather catches you out. Repacked exhaust to reduce the mind numbing exhaust noise on long journeys making it a pleasure to drive, Lockable storage area with built in tool box in lid. MOT expires at the end of July 2013. Tax expires at the end of February 2013. This car was built and registered in 1997 and has only missed 1 trip to the Le Mans 24 hr race since registration. Please email me for more photo's. Vehicle located in Swindon, Wiltshire. Viewing recommended. Price is £4,500. Call Ken on 01793535859 or 07875637284.
