Rear Suspension On S7
Guest Pauljordan
Guest Pauljordan
Hi guy and Gals,
Does anyone have any ideas how I can lift the rear of my S7 without fitting coil Overs?
It is running on standard Sierra springs and shocks at the moment but wheel arch catches tyre now and again. I've tried new springs but only lifted it by about 10 mm not enough. Need about 50mm lift.
Any ideas without major costs would be greatly appreciated?
Cheers Paul.
Should be easy enough to make a spacer to fit above the spring, but raising the ride height will effect your camber angle. The higher up you go the more the top of the wheel will move outward, if you have camber wedges fitted you may need to take out. On the s7 I had I fitted some caravan towing spring assisters that slotted in between the coils, might not be easy to find these days though.
