I'm after some 3mm steel plate for the bottom of my new sump. Must be >220mm square.
I've tried a few places locally, with little sucess, unless anyone has any recommendations?
Andy
Andy
Andy, ring Dan mate, i know he gets it ok.
HTH,
Nick.
Is this a very sad reflection of G.B Ltd. This Rhocar member lives in Sheffield; "Steel City" that was; & can't find a piece of plate.
well i had a quick run about a couple of places on friday, one place wanted £30 + vat to cut a slice off a sheet, but my trip was curtailed by my clutch quadrant exploding!
I'll see if Dan pops up ;)
Guest Getting There
Hi
If you have no luck with Dan, we have loads here at work so can guillotine a piece to suit, and Im sure it will have come from the scrap bin ;) . I will be across in Wortley on Weds evening if thats any good.
Let me know
Chris
I had a similar problem when I lived in Scunthorpe.
It surely is as you say SAD but I would think the guy who wanted 30 quid for less than a foot square was areal leg lifter .An ongoing project I have,turning plates for susp set up 4x 300mmsquare plates £22+vat at my local supplier 8/9 miles outside Sheffield .Ifyou read this Grim get in touch :good: mower man
Guest peter2b2002
there is a great place in Wem. got a 5mm x 450mm x250mm + 8ft x3/4" square tube and 9ft 1" square tube for £12.00
peter2b
Hi give us call im shore we can fine you an off cut, we are going to start selling sheet in alloy, mild and stainless as well as all the tube on the spares site
Richard
