Is It Head Gasket?
ZeroKnowledge
I would suggest you check both the head and block faces for flatness or at least the head face. Not too easy to do unless you have an engineers straight edge. My old tuned pinto used to pressurise the coolant when it got very hot and was driven fast. A new head gasket and careful reassembly didn't cure it. Stripped it again and couldn't detect a warp but the local machine shop did. They skimmed it just enough to level it off. Problem solved.
Edited by Longboarder
I have pm Les as cant get on his website to get info.
as I have a full MLS gasket & seal set, new hydraulic tappets, valve stem seals (all bought cheap incase they were needed) :)
i might as well have a go & do the lot.
will I need any special tools or equipment, Can I do anything with camshaft & valves (ie checking, cleaning)??
-its a Ford DOHC 2.0l 8v
cheers Paul
Seems we have all foul of the word assumption, me included.
The engine in repair is a DOHC Sierra and not a Pinto.
So all the advice about cam belts, injection heads are not helping. Dho.
Edited by Ian & Carole
I have taken the cylinder head off today & found the gasket between cylinder 2 and water channel perished.
the head gasket fitted was the fibre type which ford upgraded to MLS type in later DOHC engines.
also the long timing chain guide is broken.
New parts ordered so should get them next week.
I have checked the cylinder bores and found no damage they are all smooth except round the top where there is a ring of carbon also the piston tops have carbon on,
what can I use to clean the carbon off??
I will be checking valves etc in next few days
Cheers Paul
