Capri Clocks
jaimo
OK, Here you go.
I ended up buying a couple of these during my build but the others worked fine, so I never actually used these ones. I think they're OK though.
Two things to note;
Firstly, One of the circuits is broken (see third pic)
Should be an easy fix, or bypass altogether.
Secondly, There's no plug I'm afraid.
So, £10 plus £4 for P+P if you're interested?
Let me know...
Thats a good price...shame I've already bought one.....
Is there anything to look out for when fitting these i.e. is it pretty much plug & play (I know the wiring is slightly different & I've got the details of which wire is which), thinking more along the lines of fuel gauge, speedo calibration etc?
Rich
Hi Rich,
Fuel Gauge is straightforward enough. I remember clamping the sender to the roll over bar and using a piece of propped up cardboard to help me calibrate the travel of the float against the Gauge. The cardboard was marked corresponding to the tank height and I extended the float arm so that it would cover the full travel, from Empty to Full. Works a treat!
Speedo is compatible with type 9 box and std Ford running gear and so was within limits for SVA.
Rev Counter picks up from the coil IIRC.
Temp Gauge needs a Capri sender (I think it's a white collared one?).
Oil Pressure is also simple, but you'll need a T-Bar connector (Burtons) to tap off in Tandem from where the Oil Pressure switch screws into the block.
That just leaves the Ammeter, which is a bit of a pain because things have moved on since the Capri days regarding electrics. Anyway, I wired it on the Alternator wire. One at a point near the Alternator itself and one way back under the dash. The point is to get a measure of the electrical difference between the two points, which correspond/reflect what what the Alternator's doing. At least it's not a dissused Gauge. HTH.
