rthomas69
rthomas69 last won the day on February 1 2022
rthomas69 had the most liked content!
    Robin Hood 3a
    Richard Thomas
    Northampton
8,706 profile views
rthomas69's Achievements
Wheely good builder!
Wheely good builder! (4/6)
21
  1. True the discs are the same size (253mm) however the pistons in the rear calipers are significantly smaller (34mm rear compared to 54mm front) therefore not the same braking force.
  2. I made my own caliper carriers & used early Ford Focus parts (actually the same discs as the Sierra) as they don't have the 'Cosworth tax' added to the price
  3. This is from the IVA manual - Note 4: Either of the following scenarios will also be considered acceptable: 􀁸 The rear fog lamp(s) may continue to operate until the position lamps are switched off, and the rear fog lamp(s) must then remain off until deliberately switched on again or, 􀁸 An audible warning, additional to the mandatory telltale light, must be activated if the ignition is switched off or the ignition key is withdrawn and the driver's door is opened, whether the lamps in (RS4) are on or off, whilst the rear fog lamp switch is in the "on" position. I've fitted one of these - REAR FOG LIGHT CONTROLLER for new IVA rules | Car Builder - Kit & Classic Car Parts Specialist
  4. Unfortunately this happens a lot & will require an IVA test to make it legal
  5. Seems to be a bit of an issue on monocoque chassis vehicles, mine has had similar cracks in a couple of places adjacent to the welds which I have ground back & re-welded (& it's never even been on the road yet)
  6. Also a 202 block (again 2l)
  7. I found it was actually cheaper (& an easier job) to replace the whole arm (paid about £35 for a pair of Borg & Beck ones on ebay last year)
  8. There is a couple on evilbay which don't appear to have the usual Cosworth tax added.
  9. K32230 A.B.S. Accelerator Cable for FORD SIERRA (autodoc.co.uk)
  10. rthomas69
    Brake
    I've fitted a Focus master cylinder without the servo. One of the reasons I went with this one is because I've fitted Focus rear brakes (discs) so the theory was the brake balance from this servo should be right.
  11. I've finally found a solution to the Capri fuel level without spending the £200 that people want on eBay for an Escort estate sender. I've grafted an early Beetle sender onto the Sierra unit & it seems to work ok, so for just over £20 I'm happy
  12. Jamsport in Northampton specialise duratec engines
  13. I'm finally getting somewhere with my build (had the car over 6 years, but other projects have always got in the way). I have loads of questions but addressing one at a time. I am fitting a windscreen (I know people will say it's easier to fit post IVA) but I already have the heater, wipers & screen washers fitted (I've also got a correctly marked screen) so there is nothing stopping me fitting the screen but when it comes to the support brackets they are just 3mm steel, so what have people done regarding the edges as at 3mm thick it doesn't allow a 2.5 mm rad on each side & it's not really possible to fit edging trim? Bit of a long winded way of saying 'what have people done with the windscreen bracket to pass the IVA test'
  14. Been reading through loads of posts on here & it seems the only way to get it right is to use a mk2 escort estate sender - found a nos one in Australia for about £230 on ebay so that's not an option. I guess it works within reason as it is so will worry about it at a later date.
  15. rthomas69
    Fuel gauge
    I’m sure this must have been covered at some point. I’m fitting Capri clocks & I’m struggling with the fuel gauge (Sierra sender) as in it only goes half way when it should show full has anyone done the same or know how to address the issue?
