I have looked on the internet and I am getting different results.
Does anyone know the torque setting when fitting ERA sump to ST170? I have to undo 4 main cap bolts to fit the windage tray.
Any help appreciated.
Thanks Mark
Hi Mark,
Detalis from LOCOSTBUILDERS.CO.UK
These tightening values are for standard bolts in a us focus svt, the engine is identical to the st170 lump.
Main bearing cap bolts
Stage 1: 25 Nm
Stage 2: 60 degrees
Connecting rod bearing cap bolts
Stage 1: 35 Nm
Stage 2: 90 degrees
Thanks Maca, I was not sure if this applies when I am replacing the bolts with the ones from Tiger Racing. They say 60 lbs ft. I feel more comfortable with angle guage.
I am coming at this from zero knowledge of this engine, but it seems odd that the conrod bolts are far tighter than the mains bolts, or is that all to do with different stretch properties?
Just interested.
Your main end bolts are typically much bigger though, plus they're not getting flung around at several thousand rpm :) I would just suspect the loading on the rods is higher than the crank caps, but that's just my FingerInTheAir-o-meter working rather than anything quantifiably backed up by science :D
I agree, plus the Conrod is only 2 small bolts versus 10 for main end bolts and much larger.
I will try on the weekend and follow Tiger Racing instructions I have a calibrated torque wrench. What could possibly go wrong.....famous last words.
Just for interest I'm building a modified Redtop (again) using ARP bolts everywhere.
The settings are 32 ft lbs big end bolts, and 65ft lbs mains studs.
I am guessing you're saying that for the fact the mains studs seem higher than the big end bolts but do you not have instructions on 2 or 3-stage angle-based tightening *after* that inital torque setting?
A bit off topic now, so I'll leave the thread for the OP's st170 question after this.
Thats the final figure. I tighten in 3 equal (ish) steps, finishing up at 32 and 65.
But I stress they are ARP non-stretch bolts/studs, so no direct comparison for stretch bolts.
The rod end bolts torque figure  seems crazily low, but this is the 4th redtop ive built, all using ARP rod bolts.
One was even designed for 8k rpm with forged rods, & is still running strong (right Kevin?)
https://tech.arp-bolts.com/instructions/109-6001.pdf
