379 -
15
Calendar
Everything posted by maca
I made mine as picture, if you know someone that can use a sewing machine and you take your time then it can be done.
Hi Neil, A picture of how mine is connected. The pic shows the small lead to the chassis at the R/H side then the large lead from the Battery terminal to the starter motor mounting bolt engine earth.
Put a shakeproof washer each side of the cable terminal. I take it that you have an earth lead from the battery to the engine as well as the chassis connection?
Many thanks for a great day out Sunday, makes a change to see people out enjoying themselves. So enjoyed the drive out, just about managed to keep up with everyone. Andi have you tried phoning your number and fix that hole in the floor? Regards Martin
Hi Iain, Just had a look on the member map and it looks like you have 5 members in Scotland maybe more. Where abouts are you ? Regards Martin
Hi Welcome to the club, another member asked the same question some time ago try the web site below. https://www.coveryourcar.co.uk/store/home.php?cat=732 They do indoor or outdoor covers.
Hi Tony here is a picture of mine. The measurement is from the top of the windscreen (where the mirror is fitted) to the c/l of the roll bar.
Top front of windscreen to centre line of roll bar 42" Regards Martin
Thanks for the comment hope that the LUK clutch works ok for you. My Son is not a great one that likes those clutchs, just depends how much power you put through it. Regards Martin
Fitted a 3pc Valeo clutch to my 2 lt pinto injection, not had a problem with it. Was about £90 back in 2016/2017.
IVA manual section 12 Interior Fittings Read Required Sandard (7) and see Notes 6 & 7
This may help you this is a copy I sent with my details removed. Your Address Here KITS & REBUILDS DVLA SWANSEA SA99 1ZZ Reference (registering a new vehicle) Dear Sir or Madam I wish to apply to register a kit car following IVA test. I have enclosed all documents I am aware of requiring along with donor vehicle V5C (registration number (********) I wish to apply for an age related number of the old vehicle. I have filled in the relevant forms and given answers that I am able to but am not to sure how to answer some of the question details requested. If there are any other details that you require then please inform me of this. I have enclosed documents as below. V627/1 V55/5 IVA PASS V5C of donor vehicle The registration fee £55.00 The road fund payment £ ( not sure of latest charge ) 6 or 12 months Regards
Robin hood video14 Watch from approx 27mins and 43 mins
What enjoyment can you get for less than £1.00 a day and put a smile on your face. I SORN mine for 6 months and drive when the weather is nice. How far can you go on the bus for a £1.00 Pay the money and enjoy the drive !!! Tried a cat but it kept jumping out.
You may find that by pulling the sides inwards a little the bonnet will fit better. Just needs a little tweak. Where you have slid the bent stiffing panel you may be able to fix a small angle piece to help stiffen the panel straight along the top tube. At the moment it is sagging down, it needs to be supported. I would not recommend doing anything to the nose cone, to let the bonnet go back any more. Mine has about a 1" overhang from the side tubes at the corner.
I am with Bob, mine had about a 1" gap. You have the option of how you wish to fit your bonnet. My son and I choose to have a fixed scuttle and hinge the bonnet forward. You will need a foam strip to seal the gap between the bonnet and the sides.
You could try Wolfrace Wheels or one of their dealers. Send a picture of your wheel. Wolfrace Wheels (UK) limited, 6A The Street Industrial Estate, Maldon, Essex, CM9 4XB Company Reg. 2406254, VAT No. GB570445054 wolfrace.co.uk – New Shop sales@wolfrace.co.uk 0845 330 9896
https://www.rhocar.org/index.php?/forums/topic/49218-body-panels-from-kit-spares/ Try the above link from one of the other members when he replaced his panels. He has made a first class job on his car. Regards Martin
If you fit some threaded bar with 2-nuts and washers on the inside of the brackets. You can expand the gap to allow the wishbones to fit after removing the bar and nuts ect. Then clamp up when fitting the correct bolts.
