I think it would depend on your radiator or expansion tank.
I use a 13lb cap on my 'coolman' radiator that came with the RH kit. I think its cortina based fitting but others can confirm.
I'm using a 15lb cap on a 2.0 pinto with an aluminium radiator and expansion tank.  I think most ordinary sierra based systems are in the same sort of ball park and a 13 or 15lb cap will get you going.
Thank you for your input Foz ,tried a 13psi did not fit will try a get a 15 psi cap I hope.got a a other question any idea were to get a set of headlights lens with a pilot light down were I live can not get any .
