4,797 -
106
Posts posted by tractor
confirmed and deposits received
kerry
richy
markb
chris
matt
andi
so got a date weekend of the 18/7/20 you can stay on the friday and sunday night if you want its £15 a night per tent / caravan and maybe hook up if required there is a toilet and shower it is only a small place but basically we have a field there are some woods and a canoe launch onto river tame so if you are interested then book your place a £5 deposit required by paypal to chrismith2@msn.com
Hi everyone I have secured a venue for a weekend camping meet in July I am visiting the site this weekend to check out services if any and cost and how many can attend so if you are interested please post up the site is in the Kingsbury area tents and caravans welcome and maybe hook up so please post up if interested
my wife is a goverment civil servant and now working from home so i get to hear a lot of the conversations and to me it is utter madness what hoops she has to jump through to do her job if a private company worked like that it would have gone out of business many years ago
i have a pinto carb going spare it is auto choke but i think it can be converted if you are interested
when i had my 2b i got rid of the servo by fitting the GBS zero pedal box anything is possible if you have a grinder and welder
yeah mine was that much but not next year its exempt
No you don't have to move the pivot pin on a type9
I would say your flywheel is putting the clutch in wrong position because a pinto clutch and release bearing should work perfectly
I fitted the zetec 1.8 clutch and flywheel wheel to my kit and worked great till I turboed it
think i would go with peter check out fuel system
had a problem with my 2b it would start up from cold fine foot down pull away full throttle belted along but once it was up to temperature it would pop and bang no power but would tickover fine turned out the fuel was vapourising in the pipe so i re routed fuel pipe away from heat sources and reduced the run of pipe were i could ran fine after that
through out my childhood i never had a new bike i had to go to the tip and make my own those were the days recycling
when i fitted a zetec to my 2b i had to remove the servo i used the GBS pedal box the first drive was scary but i soon got used to it
the wide body GT ZERO manifold fits i fitted one to my 2b
i would get it working properly first before you start trying different things
if i could go back to how mine was with the megajolt and bike carbs with the Mtech vvt controller i would cos i regret it was awsome to drive
have you driven it with the vvt working correctly yet mark
mine was registered in 1979 whilst it is now MOT exempt i missed out by two months on being tax exempt GRRRRR
the MOT exemption is a rolling 40 year period from the looks of your post i should have waited to tax it cos i didnt have to i think a conversation needs to take place with DVLA robbing gits
they will fit the engine but not the chassis you would have been better off getting the zetec diy mounts from retro ford when i converted my 2b to keep the engine central i had to use 1inch box section to to make one engine mount plate wider and the retro ford tubes are longer than the kit spares set
do you mean HOODSTOCK Mark
afternoon guys and gals just a quick question because i just cant remember does a 4 speed type 9 have the same number of splines as the 5 speed type 9 at the prop shaft thanks
B2 Dash board
in Fitting & bodywork
from your video it looks like a S7 but it could be a B2 cos i have never heard of that now if it was a 2B then i used to own one and it dont look like that
