Pintogogo
Everything posted by Pintogogo
  1. Bit of a longshot but... can anyone recommend a company that manufactures or supplies Stainless steel 4 into 2/1 manifolds for a 2.0 Pinto in a Robin Hood S7 in the North / Nor​th East. Thanks in advance Harry
  2. Hi Steve I'll be there all being well, looks like a tin top job though eh lol, see you all on weds Harry
  3. Hi Guys I'll be there all being well n I'll bring the kit if its not raining, (otherwise its tin top time lol) See you all weds. Harry
  4. Thanks Guys
  5. If you go for mini wiper motor try to get 2 speed unit as it has a self park unit fitted to it
  6. Pintogogo
    Pinto Timing
    Just fitted an accuspark electronic dizzy, coil, 8mm silicon leads n Iridium plugs and car started straight up, but ticking over about 1200 revs, timing marks (8deg BTDC on pulley I think??) looked way out with strobe but when brought into alignment engine seemed to slow down n not run as smooth, on road test it seemed to be pinking quite badly. Can anybody recommend ignition settings (possibly with diagram of cast pulley marks) for a 2L (205 block) engine to help me out Thanks in advance ( no pun intended lol) Harry
  7. Thanks for advice guys, I purchased new accuspark, coil, leads n plugs, I'll set timing then hope for best Harry
  8. Thanks for the help guys, it is much appreciated, I've been looking at accuspark kits on ebay (dizzy, coil, leads n plugs) and was wondering will one kit fit all as I think my dizzy is a Motorcraft one ( black dizzy cap, spring contact on top of black rotor arm), or are there kits to replace Bosch and Motorcraft separately?
  9. Engine idles steadily and it is a 'popping' in the exhaust (like a backfire), when the revs are dropped and then the accelerator pressed the engine pops for a second before picking up, I'm at work but i'll check vacuum connections and dizzy when i get home. Thanks for your help it is much appreciated
  10. Thanks Fossett PM sent
  11. never had dizzy cap off, thanks will look at that, if it has points/condenser will a electronic dizzy replacement make much difference
  12. The sensor was removed to refurbish the wishbone but it looks to be back in same place (ring from lock washer)
  13. Pintogogo
    Pinto Misfire
    My 2.0 pinto tends to misfire when revs drop when changing gear, car picks up and accelerates well but misfire annoying, replaced plugs leads etc, has anyone had similar Cheers - harry
  14. After removing front wheel to have puncture repaired my digital speedo has stopped working, I'm not sure if there should be some sort of pick up on inside rim of alloy to allow sensor on wishbone to transmit info to dash, all other functions (fuel, trip, water temp etc OK) can any one shed a little light on this - cheers harry
  15. Hi I saw a Robin hood with Black soft rubber trim around front mud guards which was about 15mm wide & looked really neat, all I can find at GBS/CBS n Flea bay is 10mm wide trim, does anyone know suppliers of a good rubber 15mm trim? Regards Harry
  16. Hi Steve I would be up for it deffo mate Harry
  17. I'll be there, see you all soon. Harry
  18. Thanks for suggestions chaps, a westfield owner from Darlington loaned me his superb trailer free gratis, project now safe n sound back home
  19. Please, Please, Please and I know its a bit of a longshot, but is any member able to hire/Lend me a car transporter/trailer in the Sunderland/Durham area to pick up my next project on Monday 22nd or Tuesday 23rd June Please Kind Regards Harry
  20. Hi Steve, Can i buy one from you please, if you PM me your address I'll send cash or would you prefer PAYPAL. Regards Harry
  21. Hi guys I'll be there as well, look forward to the crack. Harry
  22. Has anyone got a spare type 9 gearbox lever they want to sell please
  23. Hi Guys, I'll be there, look forward to the crack Harry
  24. I'll be there, all being well. See you weds Regards Harry
  25. Pintogogo
    Help Needed
    Haahahaahahahaahaha Nice ones, Thanks guys (I asked for that) LOL Harry
