1,714 -
19
Posts posted by jaimo
I know its not a kit but is anyone any good with caravan electrics
Basicaly when pluged into mains it charges battery at 13.5v so perfect but doesnt doesnt stop charging and cooks battery and
When plugged into car it doesnt charge battery at all yet got power to the 2 relays swopped them for new and no change even bought new switch control panel no change
Does the car power go through the charger
I will have a look chris
How do you input the values chris
Getting some pinking preignition
Has anyone got a map for megajolt
2.0 pinto with r1 carbs
I got the software on laptop and megajolt connects and can see map and setting etc but how do you change map do you have to input values into grid manually
Wood cut your own and cover it easily done
Not sure what the rear suspension looks like might have some spax if you get pic and measurements up
Exhaust needed dean let me know mate
Got carbs r1 just need manifold
Bike carbs for now dean
Pm u chris
What flywheel chris
Changing pinto out
Going for pinto clutch new flywheel
think going to need water rail which one is best
I like duratec would be better to keep exhaust same side but the belhousing etc and finding a good engine at right money
As above what you got
Getting things ready for winter
I have got
Megajolt
engine mounts
Need everything else
Hope these help
Steamer on here does them if he still does do them
I fitted the mod made by steamer so far so good as replaces bearing
The top mount if i understand correctly what you ask is a big washer basically top of spring
Is anyone interested in this
Caravan
in Electrics
Tested car on anorther caravan all good and anorther car on my van no good
Factory fitted and all working
Fitted loads of towbars over years and yes know all about telling ecu or by pass
Had caravan nearly 10 yr and had this problem on van with last car but only just got round to sorting it
Cant get a wiring diagram so just going to have to trace back i think very complcated van for age
