2,123 -
67
Posts posted by nelmo
I dont think engine speed when starting has anything to do with the spark- it's all about the starter motor. As Bob says, earth's are the first thing to check but I had the same problem (on my Zetec) and it proved to be a dodgy starter motor. Replaced it and all good.
On 1/25/2023 at 9:59 PM, IanS said:
Albert Einstein famously pointed out that "If a cluttered desk is a sign of a cluttered mind, of what, then, is an empty desk a sign?"
Yeah but he never had to scrabble on his hands and knees through bits of old tape/swarf/oil to find that 10 mil socket he'd just dropped through the engine bay
At least it's a nice easy fix...and glad to hear AutoAid worked well as I have a policy with them as well...
1 hour ago, rthomas69 said:
This is from the IVA manual -
Note 4: Either of the following scenarios will also be
considered acceptable:
The rear fog lamp(s) may continue to operate until the
position lamps are switched off, and the rear fog
lamp(s) must then remain off until deliberately
switched on again or,
An audible warning, additional to the mandatory telltale
light, must be activated if the ignition is switched
off or the ignition key is withdrawn and the driver's
door is opened, whether the lamps in (RS4) are on or
off, whilst the rear fog lamp switch is in the "on"
position.
I've fitted one of these - REAR FOG LIGHT CONTROLLER for new IVA rules | Car Builder - Kit & Classic Car Parts SpecialistNote the text in red....this is an alternative option, NOT a requirement IMO. The actual requirement only says this:
4. The rear fog lamp(s) must only illuminate when dipped beam, main beam or front fog lamps are lit (see alternatives in Notes 3 & 4)
The IVA test doesn't care about full lock, it'll be fine on the edge. In fact, I think it looks quite good...
I got through IVA (in 2017) without that but I don't recall him actively testing it either.
However, I'm pretty sure that when I read the IVA manual, it was not a requirement, from my understanding, so I was never thinking about it during the test.
Almost certainly the side-arch only. There was at least 1 person who failed IVA because the repeater was on the side panel (although not sure exactly where - might be a location where it is ok?).
Look in the IVA manual, there is a complicated looking diagram showing where it has to be visible from.
Well done, although pictures are needed...
Sorry, bit late but happy hols to all
As Ian says, if you try keep the same amount of rubber, the wheels just won't fit under the wheel arches and you'll affect the speedo. If you keep it low profile, you'll make minimal different to ground clearance and the ride will be even harder than normal (if that is possible ).
It's not exactly dead, just moved 30 miles west, or so
Yeah, 'cos none of us would dream of doing that
I used small washers that were about the same size as the rivet head and small enough to fit inside the popper body - run those down the pop rivet length and they act like an extension to the gun head (sorry, tricky to explain).
I just drilled very slowly and I did hit the glass a couple of times but it's tougher than you think (as long as it's modern, laminated stuff), so you should be fine.
Details here:
https://zerolifebuild.blogspot.com/2017/12/a-roof-over-my-head.html
@richyb66 is in Tamworth, runs his own garage business and has done lots of work on members cars (including mine) - highly recommended.
I left the ECU (Emerald) out for my first startup so I could check it worked before final fitting (see here: https://zerolifebuild.blogspot.com/2016/08/a-beating-heart.html) but after that, yes, fitted on the firewall and yes, it (well, the Emerald ECU - don't know about others) does have a basic map which should allow it to get started.
If you want it for track use, I believe it needs to be accessible easily, so under the bonnet is no good. Even for road use, you really want it in an emergency, so needs to be in the cabin somewhere. I've not got one, so can't help further..
Seems like it - at least for this year...
ford serria steering cowling
in Wanted
Sure, let me know your email address...
