Matt brown
Everything posted by Matt brown
  1. Matt brown
    Zetec Rattle
    when you say you checked the big end did you take off the caps exposing the shells?? Just a note the zetec doesnt have cam chains its a belt so would not cause a metal rattle
  2. Not going to make it ether only just finished work
  3. Ye found the problem turns out the bolts to the pickup had come loose. Managed to get it fixed and hopefully no major damage done the next couple of outings will show anything up though
  4. Glad you had a good time Dan, wish I could have come but bloody car decide it didn't want it yet. Will be posting another hopefully soon
  5. Matt brown
    Sump Removal
    Bigger question did you find a problem with your engine? (Big end bearings)
  6. Yep always up for a run
  7. Matt brown
    Sump Removal
    Don't snap your pick up lol if you can lower the front of the sump you can get to the 2 torque bolts off the pick up and just bolt it back on when the sump is off
  8. Matt brown
    Sump Removal
    Get a video it will be easier to see what's happening. If it doesn't have any baffles or windage plate it can't be caught on the pick up and if it isn't getting caught on the dirt shield for the gearbox it must just be stuck on with the sealant/gasket just pry it off don't be shy they can take quite a bit of force to dislodge sometimes
  9. Well no oil pressure on a run today will try and fix for the weekend but don't know if any more damage has been done. Will keep you posted
  10. Matt brown
    Sump Removal
    If the sump is hanging off at the front but hung up at the back then it's off. You will find the oil pick up will stop you being able to remove the sump easily so you may need to unbolt the pickup
  11. Matt brown
    Sump Removal
    Just stick a thin flat head screwdriver at the front corner (crank pulley side) tap in with hammer and then use a blade to start cutting the sealant and work your way around. Do it from under the car to you can see what your doing
  12. I can't book in until payday
  13. Can we get a lasagna and fish and chips with mushy peas please
  14. Matt brown
    Sump Removal
    Ye they are a right bas74rd to get off I used a flat head screwdriver and and extendable crafts knife to cut though the sealant. Just make sure you clean the sump out before putting it back on
  15. Will see you there in the kit
  16. More the merrier
  17. As far as I know going off comments Dan + friends Keith Matt
  18. Ok great
  19. Email back from javelin, they aren't offering any further discount on the price as supposedly this is already a cheap price compared to others. Abit frustrated with this but looks like it's full price on this one
  20. I'll email them again tomorrow to try and sort it out, the last person I spoke to were not very helpful to say the least. If not we will just have to book separately and I'll try and get in touch with someone higher in the chain for future events
  21. Me and jas for lunch as well please
  22. Ok final call!! so far we have Dan + 1 Keith Chris Kevin Me I'm getting final information from them so we can collect payments asap
  23. Profile pictures are normally put up using a image hosting service which will provide you with the option for a forum image. As for signature I'm not sure but will be under your account somewhere
