379 -
15
Posts posted by maca
Peter
I stamped my own number on the chassis.
You are not being told the correct information,
On your application form IVA 1C it ask's for the VIN number at question 3a (ii)
At question 3b Position of stamped VIN on vehicle.
Your date of manufacture question 4b Is the date you submit you application form.
Do you have a manufacturers plate fitted as sample below:-
You have the brakes designed for a 4/5 seat saloon car that was quite heavy loaded.
The front of our kit cars is very light so the front brakes are going to lock up very easy.
It is more the driver learning how to brake in a very light front ended car that has little weight to hold the front wheels down on the road.
Need I say any more, practice light braking and apply less foot pressure, we don't have ABS and driver aids, just common sense.
The image is taken from a friends wiring of the doner loom so I would assume that your wiring would be the same.
You can clearly see the flasher unit hanging from the harness in the picture so follow the 3-core wires back to the main loom.
So where was it located before you found it?
Think you have a little bit of water ingress!
If you can trace the wires from your light stalks then you should find a 3-wire circuit with a triangular 3 pole plug fitted that
should have the flasher unit fitted as behind the dash board.
Hope that helps. Not in the fuse box.
It should come out the loom at about the same point as the brake light switch wiring.
Depends what switch you have maybe.
On mine with ignition switched on you switch head lights on then the left lever controls as:-
Away from you Main Beam, Centre position Dip Beam & Pull towards you Flash Main Beam.
Without ignition switched on only side lights.
On 8/12/2020 at 9:05 AM, NickandNeil said:
I m waiting for my IVA twidling my thumbs reading all the kit car forums green with envy at the blats everyone is doing. I noticed a comment on one site saying it is almost impossible to get an Exmo through the IVA test. Is there anything I need to know like extra strengthening etc? You guys have guided me over the last two years of rebuild, but no one has mentioned strengthening?
Also has anyone had a test date through yet? and if so, when did you first apply?
Hi Neil,
How long ago did you apply for the IVA?
I applied for mine on 8/5/2017 received an email 11/5/2017 to say application received then 15/5/2017 application accepted
Made a payment on 15/5/2017 fee £450 received an email payment receipt 15/5/2017 also a email Application Assessed
Then nothing from them until I phoned them as to how much longer it would be to wait on the 10/7/2017
I was told by them that I had not payed the fee, I told them that I have payed and have a recipt dated 15/5/2017
Then on 10/7/2017 received an email (Your recent application has now been processed by DVSA Testing and Support Services (TaSS).)
Then again on 10/7/2017 (Your application for Individual Vehicle Approval has been released for inspection.)
Then again on 10/072017 and the 13/7/2017 (A Booking Appointment) at my choosen testing station for the 24/08/2017
Pleased to say it passed first time.
Then it's the good old DVLA to get it registered and Number plates. so another month and you maybe there.
CONTACT TAS 0300 123 9000
36 minutes ago, Gerhard said:
Here is an picture complete drve shaft. The "Bell" are the black Parts at the end. drive shaft
How about this part is this what you are looking for ebay 130545315788
Regards
Martin
Not to sure what you require are you wanting the CV joint as well or just the bellows?
Another option is to fit the split type of bellows never used them myself (ebay No 353081359844)
Regards
Martin
If you have ebay over in Germany then item No. 353081380624
Hope that helps you
Regards
Martin
Question do you mean a Zetec or a Vetec as you have changed the word on a regular basis?
What gearbox is the S7 engine got fitted?
The Zetec is fuel injection in the S7 so the ECU would need to be changed also.
The 2B on ebay is also Injection but not the same ECU. and I am sure would have a type 9 gearbox fitted.
As (madh) said there was never a B2 the car was called the 'tubey' by staff and the 'Project 2B' was adopted as the kit name.
Thanks once again for the video, what an adventure to have a drive like that.
Question for you what camera mount are you using as I would like to get the camera and mount with a couple of batteries,
Has your gear lever always been that loose just wondered if the spring is not holding it firm as I see you holding it quite a lot in your driving.
Having just got an MOT pass for the next 12 months and a car that has the Zetec engine then why would you wish to change.
Do you have great difficulty getting in and out or is the fit to tight for your comfort.
The 2B on ebay has an alligator bonnet not lift off like yours some people like it others don't, the choice is yours.
Once again a well put together video, how could we get bored with views like that.
Just wondering when that big dog is going to pass you on the road started at 0.09 sec's and have not seen it yet or was that
the lovely road you where travelling on before the St Bermard Pass.
3 hours ago, John Gaunt said:
Hi found out my windscreen is to far forward, trying to sort this so weather gear will fit properly, need sizes from windscreen to rollbar, or back of car.
Thanks.
Car 2B that should be the same. Top of windscreen to C/L of roll bar 42" to back of car 68"
I am sure that was the dimension that Richard of RHE said that it should be in his video's.
Yet another good video Neil.
Thanks for the entertainment shame about the cable but if that was the only breakdown then an excellant journey.
Thanks for the details of the camera used.
Regards
Martin
Pleased for you that the car passed MOT mine is booked in for Friday.
Now get in it take the car out and have a good drive much better than sitting around at home.
Thats what it's there for to put a smile on your face.
Regards
Martin
Great video Neil the views are wonderful.
Looks like you had a most enjoyable time and not one stop for fuel.
What camera equipment have you used?
Regards
Martin
Try Burton Power
Are you wanting the tie rod drumstick or the track rod ends this page should give you both options.
https://www.burtonpower.com/steering-tie-rod-drumstick-ford-sierra-cosworth-2wd-sc920.html
Check the motor brushes, you could have a worn out brush.
Thanks Gentlemen for your quick replies.
I hope that I can be with you some time Saturday morning.
Regards maca
Martin
4 minutes ago, richyb66 said:
I live in Tamworth, I went to the venue yesterday. My location is correct.
So I take it is the road with the barriers sign posted (CLIFF LAKES)
North of Cliff Hall Lane,
Many thanks for your quick reply
Martin
VIN stamp confirmation
in IVA
I have to agree with everyone else that it is not required.
MR IVA TESTER will check that the chassis is stamped.
And that you have a manufactures plate fitted showing the correct details.
As IVA Manual Statutory Plates 18
In my case I made up my own VIN number and submitted it on my application Form IVA 1C
NO further action required by you to have it checked.
