NeilD
Everything posted by NeilD
  1. to get the housing off the sump has to go.........................
  2. in theory no.... should be able to remove the fan pulley etc and 'hook' the old seal out - then 'gently' slide a new one in. usually works as long as the old one is cooperative seem to remember you have to put a bolt back in before using a puller to get the pulley off
  3. NeilD
    Finally
    Welcome to the mad house
  4. Jim - drop me a PM and I'll drop round As the others have said it looks like it will be IVA which nobody has been through yet.... The last couple of cars I looked over both passed 1st time at Glasgow Neil
  5. NeilD
    1st Time Pass Glasgow
    Well done Have to agree Glasgow SVA was fine and helpful when I did mine too. I also had no issues with Edinburgh DVLA - no huge queues - paperwork handed in one day - reg plates the next Have to organise a wee blat one day
  6. NeilD
    Test
    bolts2.doc
  7. NeilD
    Test
    Bolts2_3_.htm didn't work
  8. NeilD
    Exhaust Wrap
    I used stainless steel cable ties to secure mine - some here linky not convinced it does much other than create lots of steam when it gets wet!!!
  9. The boot is a stainless steel catering tray..
  10. GBS sent me one of the new ones in error. I gave up on it due to alignment issues with the servo and ended up sending it back for the old style. ( still had issues with that one -had to 'adjust' stuff under the bonnet ). I did consider 1) going servo-less 2) remote servo
  11. rev counter not needed for sva to do the emissions test they can use one they just attach to your engine
  12. NeilD
    Water Pump Gasket
    replaced the bolt nearest the leak with a shorter one - so far its looking good of course this was after a trip to the motor factor - more spare bits......
  13. NeilD
    Water Pump Gasket
    Any particular brand - there seem to be lots around - thanks
  14. NeilD
    Water Pump Gasket
    water pump on my 2.0 pinto started leaking over the winter. treated it to a nice shinny new one... first attempt ( no sealant just the gasket ) and it leaked at the top second attempt ( found some blue hermatite lying around in the garage, gave the gasket a light coating each side and fitted ) all OK until it got up to temp and now has a small leak again at the top. any suggestions for getting a good seal on attempt three
  15. NeilD
    Ran Now Stopped
    Does sound like it could be the coil.... they normally give pretty weird symptoms when failing.
  16. NeilD
    Chequered Paint
    having difficulty getting the right tartan
  17. NeilD
    Sample Pics
    did you switch on sharing on your photobucket album?
  18. NeilD
    Golf Electrics
    MKIV FUSE LIST 1. Washer nozzle heaters, glove compartment light, memory seat control module (10A). 2. Turn signal lights (10A). 3. Fog light relay, instrument panel light dimmer switch (5A). 4. License plate light (5A). 5. Comfort system, cruise control, Climatronic, A/C, heated seat control modules, automatic day/night interior mirror, control module for multi-function steering wheel, control unit in steering wheel (7.5A). 6. Central locking system (5A). 7. Back-up lights, speedometer vehicle speed sensor (VSS) (10A). 8. Open 9. Anti-lock brake system (ABS) (5A). 10. Engine control module (ECM): gasoline engine (10A); diesel engine, Model Year 2000 > (5A). 11. Instrument cluster, shift lock solenoid (5A). 12. Data Link Connector (DLC) power supply (7.5A). 13. Brake tail lights (10A). 14. Interior lights, central locking system (10A). 15. Instrument cluster, transmission control module (TCM) (5A). 16. A/C clutch, after-run coolant pump (10A). 17. Open. 18. Headlight high beam, right (10A). 19. Headlight high beam, left (10A). 20. Headlight low beam, right (15A). 21. Headlight low beam, left (15A). 22. Parking lights right, side marker right (5A). 23. Parking lights left, side marker left (5A). 24. Windshield and rear window washer pump, windshield wiper motor (20A). 25. Fresh air blower, Climatronic, A/C (25A). 26. Rear window defogger (25A). 27. Motor for rear windshield wiper (15A). 28. Fuel pump (FP) (15A). 29. Engine control module (ECM) gasoline engine (15A); diesel engine (10A). 30. Power sunroof control module (20A). 31. Transmission control module (TCM) (20A). 32. Injectors: gasoline engine (10A); diesel engine (15A). 33. Headlight washer system (20A). 34. Engine control elements (10A). 35. 12 V power outlet (in luggage compartment) (30A). 36. Fog lights (15A). 37. Terminal (86S) on radio, Instrument cluster (10A). 38. Central locking system (with power windows), luggage compartment light, remote/fuel tank door, motor to unlock rear lid (15A). 39. Emergency flashers (15A). 40. Dual tone horn (20A). 41. Cigarette lighter (15A). 42. Radio (25A). 43. Engine control elements (10A). 44. Heated seats (15A). Fuse arangements in fuse bracket/battery: S162. Glow plugs (coolant) (50A). S163. Fuel pump (FP) relay/glow plug relay (50A). S164. Coolant fan control (FC) control module/coolant fan (40A). S176. Relays panel interior (110A). S177. Generator (GEN) (90 Amp.) (110A). Generator (GEN) (120 Amp.) (150A). S178. ABS (hydraulic pump) (30A). S179. ABS (30A). S180. Coolant fan (30A).
  19. NeilD
    Golf Electrics
    sounds like the central convenience controller needs attention try on here for someone near you with VAG COM software ( I have but i'm a wee bit far away ) uk-mkivs
  20. male of species - read instructions - does not compute I'll be asking for directions next
  21. is it just me - I feel I HAVE to build one........... bit like the bl**dy car then......
  22. NeilD
    S2000
    Don't the engines spin the wrong way ???
  23. NeilD
    Efi Fuel Pump
    It lives again.... Removed the fuel pump - tried connecting to a battery, reversed connections etc and gave up after a while. Had a look at fuel pumps on the net but there are so many and so many fittings I gave up on that too. Back out to the garage - bloody hard bang with a hammer and a bit of verbal abuse and the original pump burst back into life It was crud in the pump - I had put the filter back the wrong way round - DOH
  24. self amalgamating tape will cover any edges for a lot less than nut covers. s a tape
