313 -
13
Everything posted by RedTrev
They sell it with a 4GB: http://www.7dayshop.com/catalog/product_info.php?cPath=777_1&products_id=110354 or an 8GB: http://www.7dayshop.com/catalog/product_info.php?cPath=777_1&products_id=110352 HTH Trev
The answers are all in here: http://www.businesslink.gov.uk/bdotg/action/detail?itemId=1081997083&type=RESOURCES Download the manual. Trev
No, you're not reading the table correctly. The left hand 4 columns refer to the state of the control switches. The right hand 4 columns refer to the allowed condition of the lights relative to the switch state in that particular row. Don't know if that's made it any clearer or worse..lol Trev
Hi Webby I'm interested in the head as I have a Pinto with a head that's not converted to unleaded. I have family that lives in Rochester who are back from France on Wednesday this week. Are you ok to hold it until then? Cheers Trev
Yes, there are different wheelboxes but the sweep can also be alterered by changing the gearwheel in the Lucas 14W wiper motor, as NeilD suggests. The gearwheel itself comes in only one size; the sweep angle choice is determined by the position of the crankpin that connects indirectly to the flexible drive. This crankpin is welded to the gearwheel at a defined distance from the centre. The further from the centre, the bigger the sweep angle. The sweep angle is normally stamped on the gearwheel. I changed the wiper motor on my 2B from a (broken ) Mini one to a new Land Rover one ( ). I swapped the gearwheels as the Landy one had a different sweep angle. Trev
Keith, Try a Spal 16". Available from Stafford Vehicle Components for £85 inc p+p Trev I've just looked at their website and can only see the Spal pull fans, no pushers... sorry for the bum steer!
Hi Mick, You need a split charging system, have a look at this site, LINK Trev
Well we've got monster pigs on one thread and monster dogs feet on this one... it reminds me I went to the zoo just the other day, no aminals there apart from a dog.... was a sh itzu.... Ok, I'll make this my last bottle of Hicks Special Draught and toddle off up the wooden hill
He's practicing for the next game of Twister
Hi Nige, Working from Left to Right (or from the M of Motorcraft to the last T ): 1) to coil -Ve 2) to coil +ve 3) to starter solenoid (crank signal) 4) to inductive trigger (in distributor). Brown/Red wire on mine. 5) also to inductive trigger. Light Green/Yellow on mine. 6) to ground. HTH Trev
Cue dog jokes...... A three-legged dog hobbles into a wild west saloon. He sidles up to the bar and announces: "I'm looking for the man who shot my paw."
Hi Andrew, I have the workshop manual for the MGTF on CD. I don't think there'll be much, if any, difference between F and TF regarding the clutch. The disc also covers R25, R45, CityRover, ZR and ZS (2002 Model Year to 2004 MY). It includes workshop manual, circuit diagrams, overhaul manuals, accessory fitting instructions etc etc for these models. I'm sure I have the disc for MGF somewhere but can't put my hands on it. I can send a copy of the disc to you if you want? Trev
Paul, I'm not in a position to be able to come over to help you , sorry, but, as a rule of thumb, when you have multiple faults like you describe the first port of call is the earthing. Check all earth points are sound. It's best to undo them, clean up as necessary and remake. Check the condition of the wires going into the earth eyelets etc Good luck, Trev
Chris, The -ve terminal of the coil is part of the low tension circuit and is connected to the electronic module and also to the instrument pack for your rev counter. It is not normally connected to ground/earth/battery negative. Trev
Found it! Bolt Grade
I downloaded the pdf from Tessco Technologies at www.tessco.com If you can't find it or it's no longer there (I just looked and couldn't find it again!) then I will email it to you, unless there's somewhere on this site to upload it to???? Trev
Tony, Mine have an "L" on them but also have 3 radial lines. Do yours have the 3 radial lines too? My understanding is these lines are the American markings. 3 radial lines on a bolt from 1/4 through to 1 inch are equivalent to 8.8. HTH Trev
Hi, I have just measured the engine mount bracket thickness on my car (2.0l pinto from a Sierra) and they are appox 35mm. If yours are the same then the mounts in my picture are not long enough for you either. ..close but no cigar. Probably need a threaded stud lengh of around 60/65mm unless you do as Dave said and extend them. Trev
Graham, Did you get sorted? The pic shows 2 brand new engine mounts that I have. They mount a 2.5 litre diesel engine. They look quite similar to the Sierra ones. Does anyone out there have the dimensions for the Sierra ones? If so, how do they compare to the ones shown in the drawing in my previous post? Maybe these are the answer to our engine mount problems! Trev
Wakey wakey Andy C , I think Sue's comment about being rude about her style of car was aimed at you not me , after all it wasn't me who said, and I quote: ......all I did (your honour) was ask if RHSC made the kit... I rest my case.... Trev
Good idea Nishka but sadly against my principles ... I believe women (and men I guess!) get suspicious if they receive flowers Theres always a way around a problem though..... how about this Sue?:
and so they shouldn't... as I didn't! It's a deal Sue, in fact you can start being horrid now... I have driven it. (albeit only twice and no more than 50 yards!)
Oh wow Sue...yours looks sooooo much better than the one for sale. ....and congratulations on keeping your job..... how could they have coped without you. ps, you should receive a cheque from me tomorrow ... no, not a sweetener, 'tis membership fees Trev
