710 -
Posts posted by miikae
You could always try these also http://www.isspro.com/ , they can be bought in the uk but they may be cheaper direct from the states , they will send you a catalogue if you request one . These are the ones i fitted a while ago .
Mike
Hi , Try these on ebay stainless 330099217959 , just bought some myself , holes in them are 4.2 mm , just measured them .
Mike
Lost for words , what a very sad day indeed .
OOPS sorry for the bum steer Peter , that makes my loom a later one then as i thought or assumed that it must have come the original donor vehicle which was an 82 , obviously not then , Pleased that you got it sorted so now you can go out on your late night sorties again
Mike
Yes Andy , i got it off the same sheet you posted , just had it by my side .
Mike
Hi Peter , side lights fuse 5 lh , fuse 6 rh , i hope is is just that or you may have a switch problem .
Mike
OOPS a big fine eh , i suppose they will appeal against it , Did they leave the driver's alone points wise .
Look in my garage for vent pics
Mike
Hi , When i did mine i used stainless button heads with nylock nuts on the inside of the tunnel .
Mike
Stainless as we all know can be a problem to work at times , all depends on grade and another big factor is its age as it does age harden , although it can be worked a little easier after it has been annealed , Nibblers can be used ofcause if it is not too thick or too hard . Try a sample piece first if possible .
Mike
Fitting bonnet vents certainly helps cool things down , as i did a while back , i used an air disc cutter and a air saw to cut the holes out , mind you that was on a mild steel bonnet , on stainless i would only use a thin disc cutter ,
Was it worth it in my case oh yes .
Mike
Took ages to read as my eyes kept watering but worth every wasted minute , oh what a star and a story teller too .
Mike
AVO deserve everything they get after that outburst or should it be that they are not going to get , silver spoon arrogance by the sound of it and what a plonker .
Mike
Hi , if you are running a pair of twin choke carbs then they are in need of the mixture setting up as you appear to have all the symptoms of out of tune carbs . An easy job to sort out yourself if you have got the gear .
Mike
Hi Craig , I dont live that close to donna nook now but i know it well as i have spent quite a lot of time there in the past watching the A10's with the kids & others ,
Mike
That sounds very much like the first chapter of one of Spike Milligans books where he was talking to his dad about the way that woman was so gracefull with the pick and shovel a lovely mover too , then he said that air raid will be a lovely job when your mum finishes it , pass me the brown ale son .
Hi is this the one you are after ebay 290156671520 as its the one i have fitted by the look of it (RH1471, THE FORD PART NUMBER IS 71BB8286CB.
Mike
I'm afraid that if it wont hold a charge then its knackered , the best advice for looking after a battery is to use something like the Optimate 3 and leave it connected , i have 2 of these one on my Virago and the other a MST battery gaurd on my Hoodie , more info below ,
OPTIMATE 3 SP - Automatic battery optimisation
Designed for 12 volt starter batteries from 2.5 to 28 Amp-hours capacity.
This is the perfect tool for regular or long-term maintenance of batteries not in daily use.
Suitable for all types of rechargeable lead-acid batteries: filler cap types; absorbed acid "MF" for motorcycles; valve regulated (VRLA); & GEL-electrolyte types.
Supplied with two interchangeable connection sets, one with clamps for bench charging, the other with in-line protection fuse and eyelet terminals for permanent connection to the vehicle’s battery.
Since i have used them i havent had to replace a battery .
Mike
Its a crying shame that he did not post earlier as it went missing last Sunday , i hope he posts some pics soon to help identify it .
I only hope that he does get it back and in one piece , a running piece too.
Mike
Sorry to hear of your misfortune Peter ,
All my best wishes go out to you for a full & speedy recovery ,
keep positive and take it easy .
I did and still do .
Mike
Hi Guy , this is what that paint supplier said (You will need a Etch Primer first, then perhaps a 2k high build primer afterwards to add protection and smooth out any imperfections )
hope this answers your question
Mike
Send them a message asking them what they recommend for use with there paints on ally , as far as i can remember we used a chromate primer first , hope this helps ,
Mike
Good idea , you can certainly count me in on this as my folder is getting a bit tatty now with all the info i keep stuffing in .
Mike
Thems wabbits will be wanting you to shoot em , as i hear that the dreaded Mixy is back again
Mike
Hand Brake Lever
in Wanted
Hi Ian , I have a Ford hand brake here that i assume came off a Sierra part no-83BB-2780-AB 80170 if its any good to you . Just come and get it .
Mike
