ozz
610 -
30
Everything posted by ozz
I got mine from Allwoods in Newark with a 3 foot bar. You are welcome to borrow it (them) although with the price of petrol or postage you may be able to get your own. Ozz
Took the zero to Russ at Torquetune for Carb set up. What a great bloke I learned a lot today from him. Well my tired 2.0 pinto on STD injection cam and Ford bosh dizzy and the injection ecu with zx6r carbs GBS manifold and gbs exhaust made 110 at the wheels. I'm well chuffed with that I was expecting 70! I then broke down (again) on the way home. The little plug on the alternator had worked loose and I ran out of electric. Managed to push it to hill and bump start it. Zeros make good scooters. Ozz
Mine went through Iva with the Ford bolt loctited and marked with white paint ( by Simon at GBS) but he would have preferred the lock nut method and I will be updating to this standard soon. I presume two roll pins front and back of the hub carrier for safety or is it one right through?
To zeroknowledge Thanks for the pic. Ozz
I've got a 1970 5p piece on my desk only 2mm smaller and would be more in keeping with your theme.
re-thinking my above post. Build wheels are a good idea if you don't have the money for your final wheels (which I didn't) or are clumsy and don't have much space (like me). If your going to the scrappy for wheels get the ones from a peugeot/citroen not a sierra as ET15 is the peugeot offset with the same bolt pattern as ford. (I think that's right). so there's more options to think about. Ozz
Be careful using standard wheel whilst building firstly they wont fit the front without fouling the wheel arch supports second on the back they wont give an accurate idea about where to fix the rear arches. One way round both problems would be 20mm spacers to take the offset down from 35 to the required 15 but you would then need to fit longer studs which would then need to be changed for the proper wheels later. The above account is what I did and i'm not happy with my rear arches and stud changing is a pain. If I was doing it again I'd get the proper wheels on in the first place. I have a set of wheels on the back garden but I'm nowhere near Kent I've now sold the spacers. Ozz
I've been thinking this too but can't work out how do you have a picture I can copy? Andrew
They look to be the same carbs as mine - Kawasaki ZX6R . You've got practically everything but... I cant see a throttle cable - a push bike brake cable one will do nicely. I've got two cable adjusters one at the carb end and one at pedal end. Also a return spring at the carb end (on the motorbike there are two cables a pull and a push) A second cable for a choke will be needed so another bike brake cable or mod you existing choke. I have a solderless nipple connecting the cable to the choke slider. Quick trip to Halfords bicycle department and you'll be sorted. The two black pipes at the top are the breathers, I have a pipe to connect the two on mine but i don't think not having one will be an issue just vent to air. On the bike the breather goes to the air box via the pipe in the back plate near to the TPS at the back of the of the carbs this hole is blanked off by the ally back plate for the filter you have there. Manifold bolts will need to be shorter due to the reduced thickness of the manifold (well mine did because I went from injection) Fitting is really easy just watch the silicone hose connectors don't pop off. That's the basics for fitting once fitted they'll need balancing and once you can do that you can come and do mine!!!!!! If you get really stuck I could come over Ozz
I Fitted a small denso alternator, mounted on a custom bracket higher than original mounting point good photos on zoom zoom's blog new belt will be needed.
Hi, Same problems here too (or so I thought). With the accelerator I put a bend in to get it as far over as possible then set the pedal lower than the brake pedal with the cable adjuster. In driving mode i rest the outside of my foot on the side panel and slide down onto the accel pedal. Similar arrangement with the clutch with bends etc. No resting place for left foot causes some pain but I can often rest left foot under the pedal as my car only seems to need 5th gear. Pre getting it on the road I thought I would never be able to drive it with the pedal arrangement but it is surprisingly easy. Ozz
Hi, When the time comes to apply for the IVA you will complete a amateur build declaration found here http://www.www.businesslink.gov.uk%2FTransport_files%2F119_IVA_Amateur_Built_Declaration1010.doc&ei=C4HPUM7uObDM0AXe0YH4Dg&usg=AFQjCNHRJr2DRn3dDIlncSpqkB_lXoPzNQ&bvm=bv.1355325884,d.d2k There is an option to declare that you bought a part built kit etc.(Section 1.4) And You make this declaration to the best of your knowledge and belief. Since no one else (other than you) can be made liable for a false declaration no one else other than an applicant for a test has to make any declaration at all. You do not need to show that the vehicle was built by an amateur from start to finish. You only need to show that a substantial part, of the construction, assembly or modification was carried out by you (an amateur and the relevant individual) or by you and one or more other relevant individuals acting on your behalf and under your direction. So you family and friends can also help too. The authority for this comes from The Road Vehicles (Approval) Regulations 2009 S6 (1) b ) http://www.legislation.gov.uk/uksi/2009/717/contents/made This is where section 2 of the declaration comes in to show the substantial parts that you have fitted the chassis/body. (see section 2 of the Declaration) It sounds like you might be (re)-fitting or updating most of these items. Take some photos of you in your garage with tools in hand admiring the bits you are fitting to support your declaration. (Sorry about the law in this post) Good luck Ozz (reading the instructions again!) (so you don't have to ) (unless you want to)
Got home now and it didn't rain on me. Had some great fun scaring the old folks and brother and nephew. Don't think i'll ever live it down at home (she's still laughing at me now.)
Now I know that I didn't fix that fuel gauge as I stand at the side of the A617 waiting for the Mrs to arrive with the fuel can.
First nice day since registration been out showing off car and learning. It is surprisingly easy to drive needs a few more tweaks. Going to take it to South Normanton tomorrow if weather holds for the Dad test.
I have taken some photos tonight hope you can work out the sides. I appear either by accident or design to have "toed in" the bottom mounts. http://s1133.photobucket.com/albums/m582/andrewosborne27/engine%20mounts/ They gave it a very thorough check over in my presence and agreed a list of work to be completed, but sadly no road test with a gps device to test the speedo; which was my fault as when they asked the question about the instruments I said unmodified, same size wheels and same diff as doner. With these answers there would be no need to "callibrate"" the speedo. So two incompetencies on my part firstly putting the needles back wrong (I made same mistake on rev counter, fuel gauge and temp gauge too and secondly forgetting that I had done so.)
After an initial fail on speedometer under reading it passed at re test and got I the plates today. I have done a budget build using as much of the sierra as possible including the sierra clocks but had put the needles back in the wrong position. So I now have an age related F plate GBS zero 2.0 pinto (ex efi) now on zx6r carbs. I could not have done this without this club and the wealth of knowledge and ideas freely given. GBS have also been brilliant. I am spoiled by living so close and being able to pop in to look at cars and talk to the guys. GBS took my car for IVA but the most valuable IVA advice came from Simon at the open day. Anyone still building should go to an open day and listen to one of Simon's talks worth their weight in gold. Finally I just want to thank 2 members who without ever meeting me or talking to me have got me to this point (I doing a Gwyneth here) I'll just say bears and gnome. Hope to see you at the shows and a merry xmas
I'm very interested in this topic having passed the IVA earlier this month and waiting for registration with a car with no date of manufacture on the manufacturers plate fitted to the car when it passed. So using the skills from the day job I have read the IVA manual, (and updated the link in the IVA section). I'm now happy that my plate with only the VIN number completed has correctly passed the IVA test. Please see the manual section 18 18.6. All plate(s) must be indelibly marked with the Vehicle Identification Number (VIN) which matches the number marked into the vehicle structure and is displayed in the correct order. (See below and notes 1, 2 & 5). VOSA MOTOR INC Name of manufacturer e1*2007/46*0291*02 Approval No. and/or Build Stage No. 3GPG918009BS51312 Vehicle Identification Number 1500 kg Maximum permitted laden mass of vehicle 2500 kg Maximum permitted laden mass for the combination where the vehicle is used for towing 1 – 730 kg Maximum permitted laden road mass for 2 – 810 kg each axle, listed in order from front to rear "Note 2: Maximum permitted laden masses are not required to be displayed but if present should be listed in the order as shown in RS6" Date of manufacture is not mentioned.
IVA MI Inspection Manual (Version 8.02) Date: 05/10/2012 http://www.dft.gov.u...tion Manual.pdf
Well loaded up the kit this morning its off to GBS for Iva and registration. Thanks to all on here for advice and build blogs. See you at stoneleigh.
we've got it so hard. I've just been nosying round a workmates brand new landy. The chequer plate is srewed on with countersunk phillips screws and one screw has gone in at 45 deg leaving a contactable sharp edge. Type approved - no iva - no ball - no problems
could be the temperature sender on the head
they say on the haynes roadster forum that the 19mm axminster handy reamer is the right tool to open up the sierra uprights to take the maxi ball joint. I've not done it myself but have the reamer and it is a very useful tool and cost 4 pounds. Search for axminster tools. Ozz
I have now hit a problem with illumination. The switch with the above set up does not illuminate until the side lights are switched on. This project is one for after iva now.
My symptoms as follows :- First attempt start with the bike carbs fuel was coming out of the breather (zx6r carbs) I tracked this to a sticking float in two of the carbs. No start. Once cleaned carbs - It started with black smoke from exhaust and I noticed the very thin oil smelling of petrol. So I Changed oil and went for a second start which ran with lots of spitting and popping from the carb very hot exhaust on three pipes. dilute oil filled the catch tank from the crank case which smelled of petrol. Still lots of smoke but not too black. cleaned carbs again (broke them) got more carbs of ebay lovely and clean. Stripped head to investigate for valve/bore problems. re lapped the valves, new valve stem oil seals and head gasket, set valve clearances properly, Went for a naughty 3rd start with contaminated oil ( well it had been sat a while with the head off thought the petrol might fizz off) very short run and got no spitting/popping exhaust did not glow. Need to change the oil for longer run to confirm sorted. Oh yes before had head off I could turn the crank by hand with the spark plugs in now I can't. Ozz
