Not that skilled I'm afraid!
There is an engineering department at work, they machined the pulley in a lathe and cut a matching hole in the trigger wheel. Once I had decided where the sensor was to be mounted then I knew where the missing tooth had to be positioned, the engineers then welded the trigger wheel to the pulley. A bit of paint and job done.
The position of the sensor was fine tuned by running the engine on the EDIS module with the Megajolt disconnected. The timing is set to 10 btdc using a timing light, if the timing light has an advance adjustment do not use it, leave it set to zero as the waisted spark confuses it and causes the timing marks to jump about.
