404 -
Posts posted by ZeroKnowledge
camped on sunday night for the first time, definitely wont be the last
hog roast was excellent aswell,
thanks to all that give their time & effort to this great club,
Cheers Paul
great footage lads, with that scenery dont know how you kept eyes on the road
see you all there
I am sure I speak for Paul (Zeroknowledge) as well as myself that we really enjoyed meeting you all at Jedbough and driving down through Northumberland to Hexham. Pleased you all made it home safely, and look forward to catching up with you at Stonliegh
certainly did enjoy the runout on wed
good to meet you all & put faces to names,
on day 5 what time do you think you will be crossing the border on A68 & where is your 1st fuel stop ?
working lates next week so an early runout could be fun
cheers for info
I know an engine should be turned over every month or so but what about a gearbox?
Iam trying to tidy the garage & shed to have a bit more space to work in so Iam moving all spares to a small loft area above the garage.
this is what I have - all from 2.0 DOHC, should they be covered in oil / WD40 / wrapped in oily paper / left dry ???
Engine (on a stand) will be stored in corner of garage
Alloy cylinder head with cams / valves etc attached (oiled when rebuilt)
water pump (new)
alternator (new)
brake calipers (used)
complete rear brake drums (used)
drive shafts (new)
MT75 gearbox (used)
Diff (used)
front hubs (used)
The wee loft is well ventilated
Cheers Paul
what bore is the master cylinder, new or used
working lates again so will be missing this week.
my car will be back on road 1st april so hopefully get some decent weather for runouts
for sale on ebay NTDWM
working lates again but hopefully finish early & see you there
cheers Paul
My DOHC sump did not have the extra capacity extension added.
I never had an oil problem.
The suggestion of a gate hinge baffle across the point where the extension fits makes sense to me.
How much did you cut from the pickup? mine was only about 1/4 inch above and parallel to the flat bottom.
Graham
actually Graham I added an 8mm spacer to the pickup where it bolts to the block as the gap was 16mm !!!!
Looking at your sump a simple one way flap would allow oil in but prevent it moving away from pick up area, you could put small slots in to allow a small amount of oil movement
finally got round to fitting a sump baffle
I chose a simple hinged flap (made from gate hinge) as Snapperpaul suggested -seemed to work ok with water, wont be tested on road till april
also adjusted the bottom of oil pickup to sump base gap to 8mm
hopefully this will do the trick
not this week as working late shift
cheers Paul
mine passed iva on bike carbs/megajolt without a cat.
My engine is from early 1992 with a letter from ford as proof, so didnt need a cat.
What year is your engine from?
Is it using all original EFI bits?
yes I did the same, just got refund cheque today.
I was driving the car on 31st oct and it was sorned at 7pm on 31st,
but dvla online automatically sorned from 1st oct.
wonder what would happen if I was photo`ed speeding and they checked records and shows up as sorned
would I be done for driving without tax???
Glad you got it sorted. Did you manage to do the tensioner without much trouble?
Les
I tried the old tensioner 1st but pushed it too far in & it wouldnt release, 2nd attempt on new one worked no probs
I didnt have any feelers to use so cut up a bean tin
once you get the knack its quite easy to do
cheers Paul
update
the original head was also cracked so had to hunt down replacement head.
found one that been fully refurbed.
this has now been fitted & started engine this morning & had short run out, everything seems spot on
thanks to everyone for info & support especially Les Welsher who has given me loads of info. :good:
might be able to change my name to Someknowledge now
from the bible of haynes its
firing order 1-3-4-2 ( no1 cylinder nearest timing cover
distributor rotates clockwise
HTH
Bonnet Catches
in Fitting & bodywork
perhaps something here could do the job
http://www.protex.com/
or here
http://uk.rs-online.com/web/c/enclosures-storage-material-handling/cabinet-hardware/toggle-latches/
