2,374 -
6
Posts posted by stevedohc2b
Try the MT 75 first it is a good one why i kept it for 5+ years
Stephen
Dave R
is the north Hants area sec i am sure he could help.
Stephen
Great day thanks Bob for sorting the tickets out
sorry i could not stay to help dismantle the gazebo.
Stephen
Chris
I think Bob is away
and yes I think so
Stephen
Problem solved it was the side vent touching the hose pushing side out so lifted hose up to curve off bonnet and it fits fine
just a cut of a cable tie.Steve the B&Q was a good call they even do a curved bracket kit.
Stephen
28mm copper plus a swept 90* bend one end & 28mm straight connector on t'other would give 31mm O/D plus if solder fittings used they will have a swaged ring which will prevent the hose pulling off.
sounds ok do you have this ?
Bob the new 32 mm hose i have is thicker than old and a bit tight to bonnet so thinking of getting it away from exhaust in metal as much as pos
Hi
i am after a length of 32 mm pipe with 90degree with a 24" straight before bend
Thanks
Stephen
What a good day 13 1/2 hour day in the sunshine.
It did get a bit steamy at times helps if you conect the rad fan back up after removing the rad to fit new wishbones.
Thanks Ail for a great day out
Stephen & Lesley
I might join in if weather is good dont think i will get the boss up early to make 9 am at coast
unless Mo gives her a push ! and weather good.
Stephen and Lesley
Ken it's the hub nut
so needs to B FTight
stephen
Most ecu need to have the TPS settings in put.
it is a variable resistor so need min and max setting.
ie software will give a reading when closed and open you have to save.
Stephen
Great result
Stephen
MT 75 gearbox runs well kept as spar £80
new release bearing and extended peg for Mt75 ( GBS supplied ) £15
Lobo joint diff brought to upgrade to LSD told was good from Member £40 what I gave.
as new recon Alternator Denso type 40 amp as
only £60
Collection or del at cost
07928112354
Stephen
All sounds good
Stephen
So could get second tosser nomination
Happy to help
Stephen
Got a full refund from eletrostart2006
will collect broken one repair and return so I have a spare.
Result
Stephen
Good Web site for info with pics
http://www.autoshop101.com/trainmodules/alternator/alt130.html
stephen
Thumbs up
Stephen
- 3
Right going for a test drive
Alternator no 3 and a new battery and charge lead
I used the American method chucked cash at it !!
hope it works
Stephen
- 2
Hi nigel
I have checked the Lead back to battery and have continuity using the original Ford cable.
I was thinking of rewiring this to the starter motor and also rewiring the ignition feed what fuse should I use for this.
Where could I get a new fused ignition feed from.
stephen
Had both tested an the rotors
have gone ,!
got told if something gong to go it will go sooner than later.
Stephen
Bob & Mo's 10Th Bbq Weekend 19-21 August
in Events
Hi sent pay pal £20
thanks
Stephen
