2,374 -
6
Everything posted by stevedohc2b
Hi I have had my robin hood on the road now for 8 months now. But the Dvla still sent me a tax reminder for the Donor. Too which I phoned and sent a letter to state that the car had been rebuilt and donor scraped with the local DVLA office keeping the original V5. So then the other day I received a fine for not taxing the said Donor from the continuous registration centre in Poole. As you can imagine I was livid A new letter was drafted then I remembered I had a fax number for the local office so I also faxed the letter to them. I have finally received a reply and they apologies as well. See attached pic. A result. Stephen Altwasser.
For sale Daewoo Nexiea GLXI 1.5 Twin Cam 16 valve 71000 miles metallic maroon. ABS, Air bag, central locking, Electric windows, Remote Boot and Filler release, MOT. New HT leads dis cap & rotor. Used by my Wife for the School run etc. My Mum is giving us her old car other wise would keep ( can not run or store 4 cars ) The robin hood must take 1st place after all. £1200 ONO please P M if intrested I am in Hemel Herts Can travel.
HI I have just got a pda with in car satellite navigation from Aldi for £270 with 320 meg ram full car kit a bargin I think. So i should get to le mans ok now. Stephen Altwasser
DAVE I HAVE A 2B DOHC SO MAY BE DIFFERENT Do not run fuel and power together keep on DIFFERENT sides if poss . wrapping the loom sounds fine do not fix to brake lines as rubbing may cause failure in brake system. Fix both every 6 ". To secure cable to wheel arch at back fix through arch in to back of the rubber light mounts if using standard rhsc lights. Or bond on some fixings /p clips with glass fiber / isopon etc. keep building Stephen Altwasser
Jim Have placed an order.Whats the best way to cut holes. I have a nibbler.aviation snips. jig saw. angle grinder.?? I think i need to get this done before Le Mans. Ps what happened about the Le Mans menu? Thanks Stephen Altwasser
THANKS JIM I WILL ORDER THEM ASAP.Do they only stick out or do they go in a bit. thinking about servo etc. re heater I also have the heater on all the time and will have to look at that one as well? Stephen Altwasser
Thanks for the replys I have the dohc car so the exhaust is on the passenger side. Have not cooked a passenger yet. the fan cuts in a quite a high temp 98c I think on this engine so the chance of it cutting in while moving is quite remote. Dose this happen on the pinto cars ie do you cook in a jam. Also can heat affect the cluch as I had a problem getting in to rev at stoneligh the other week.( mt 75 box) thanks Stephen Altwasser
Hi To suck or blow is the question? I have my rad fan mounted in front of the rad and at the moment it is blowing air through the rad in to the engine bay,and at me the driver.I sat in a jam on monday and I nearly cooked. I do not have any bonnet vents all the heat seamed to be comming around foot well. So if The fan sucked the hot air away from me would this work ok for engine. I did have it ticking over when first fitted with the fan sucking and did seam ok. So is a blow job best or a good suck!!?? Any view would help Thanks Steve DOHC2B Altwasser
Hi Paul I used a bag type from europa @http://www.europaspares.com/ worked well and is small about £12 I think .You can allways try putting it in the boot (or was that the battery)sorry Bill could not resist. have a look at my web page http://www.stevedohc2b.freeserve.co.uk/month__four.htm All the best Stephen Altwasser
TRY YOUR LOCAL NEEDLECRAFT SHOP I GOT A PRESS STUD SET AND USED THE CONE SHAPE TO HOLD THE PRESS STUD AND A X HEAD SCREWDRIVER BIT TO SPLIT AND SPLAY OUT WORKED WELL AND USED PRESS STUDS ELSWARE. ONLY ABOUT £5 A KIT. STEPHEN ALTWASSER.
Go for it the super spec is now good value at its new lower price. i han only ever changed pluges ,oil and brake pads before I built my car last year. Its great fun to do and even more to drive. The thrill of getting through the sva can only be matched to the first child being born. Go for it. You have the best club and forum behind you as well. If not a hood try this http://www.koolkarsltd.co.uk/ I have just looked at it at the show and want one!! Stephen Altwasser http://www.stevedohc2b.freeserve.co.uk/
well done not a lot at all willsail through on the re test. The car looks good let us know how you get on and see you at the shows. Stephen Altwasser
Hi i al so ran my fuel and brake lines along the top of the two tubes above the tunnel with only the power below. in the tunnel and passed the sva with out any question. i looket at a westfield at a show with them running along the floor if i had don that they would be cut and bashed by now. Have a look at my web site http://www.stevedohc2b.freeserve.co.uk/Build.htm I also have easy access if needed. keep building. Stephen Altwasser
I had to remove my peddal box cover so he could see stearing shaft a pain as I has sealed with mastic as well. have alook at my sva report at http://www.stevedohc2b.freeserve.co.uk/sva_test.htm good luck Stephen Altwasser
I have a 30 Amp push switch wired in to the back if the iginition switch to position 3.so you turn switch ignition on and push to start. I did this after the sva with a second key switch as well. Stephen Altwasser.
HI HAVE YOU GOT THE ABS BRAKE SYSTEM SPOTTED RES POKING OUT OF BONNET. AS WELL IS AT ALL ROUND DISCS? AND WHAT ENGIN ARE YOU USING.
Hi the europa one is to small. I went to by one before sva, I think that RS jig tec now do them to fit the hood for under £50. I saw a post on this sight about them on the open days. Stephen Altwasser
Try tiger racing. http://www.tiger-sportscars.demon.co.uk/ or www.luegosportscars.com Just a thought as are near you. Stephen Altwasser
Hi no 3 or 1 for me please. Do you have a graphics program to draw your designs in ie Adobe Illstrator or Freehand as I may be able to help on my Mac at work. The new RHOCAR logo would also look neat and is well drawn if not as a bonnet badge May be a Pin to wear. Wel done Stephen Altwasser
Well done where was the test at this time was it at Leighton Buzzard again. Well done can we have some pics please Stephen Altwasser
Hi stu I have just recived a road tax renewal form for my donor after the hood being on the road since Oct and giving the log book to the dvla for the build up inspection so if the local dvla and head office do not talk. I think you are safe my engine did not match log book and i still got an age related plate as you only need 3 major items IE rear axel, front hubs ,diff, gear box, all count my donor had abs the hood dos not so getting a servo from a scrap yard will be ok. Good luck Stephen Altwasser
Well done take it easy for the first few hundred miles as things tend to loosen and need checking. I am hoping to take my car out at the weekend to go to Cambridge where are you based ? Well done again Stephen Altwasser (Herts)
Hi I have only used half of the 1ft sq Foam I had fun getting that in as I have a so called swirl pot fitted in side the tank after pushing the foam through hole for sender/fuel pump (all one on dohc car) the foam sat in side the swirl pot after a lot of swearing and cut hands I manager to push it to clear the swirl pot and sender this sits in the swirl pot. So the fuel can not slosh back and forth so freely in the tank and stays in the swirl pot better. The foam now fillers about half of the tank. Well that is the idea. I can sell the rest of the foam if you need it. Stephen Altwassser
Hi I have now fitted some fuel tank foam from demon thieves a 1ft sq will hold 28 lit i have cut to size and crammed it to the tank seames to work ok so far but have not used car much after fitting so time will tell. Stephen Altwasser
HI I HAVE A DOHC 2 B CAR ON THE ROAD I AM VERY HAPPY WITH THE CAR THE ENGIN IS A BIT BIGGER THAN THE PINTO BUT GOES WELL THE DOHC KIT HAS A DIFFRENT CHASSI TO ALLOW FOR THIS. WHEN DID YOU GET YOUR KIT ?? i DO NOT REMBER THAT BIT IN MY VIDEO AND DID NOT USE IT IN MY BUILD SEE MY WEBSITE http://www.stevedohc2b.freeserve.co.uk
