2,013 -
26
Posts posted by maccavvy
If you want to sell may i suggest a bwttwe advert with pictures
Im sure steamer..shaft ..or dan among many others can answer that..they are close by
In comparison to a 2b or zero.they are an xl car very much longer and wider .in my opinion it will be a great cruiser but no sports car. The small blocks arent revvy like a 4 pot.deoends what you want from a car..and ive no idea what spares are like for luego
I wouldnt worry about losing the map...leave it connected..charge up overnight..measure voltage..measure voltage whilst cranking....measure voltage when running with lights etc on...report back.
If you got a loval friendly motor spares they usually load trst batteries and alternators for free.
Wont be there this time..couple of 1000 miles away.
As long as the orders right..it doesnt have to point to a specific place on the body...its rotor arm to no1 that matters
Aerosol nozzle ??
Have you checked the new and old cap have plug connectors in the same place.including the locating lug..??
Is the center pin in place ??
Is the rotor arm.right length ??
I can take pics when i return off holiday.
Send me your email addy.
Also post pics of your set up .may help to find a solution
Cheers bob..that was my initial thought.
But better off to ask
Ive got a t7 heater matrix to go in the kit.
See if i can make it a little more inhabitable.
Whats the best way to fit it.the top of the top of the matrix will be higher than the rad cap .. the inlet pipes can either be top or bottom ..am i best to fit to top and fit a bleed valve ..any ideas before i start
Dont have pics but mine misses the manifold by 10mm if that
Congratulations to the both of you .
check speedo cable connections 1st.
if it has a kink in it. it could have broken so check that too
as mentioned already dave at damper tech is your man.
youll need the fitting kit from GBS unless your handy with a welder and can make them yourself
http://www.kitspares.co.uk/index.php?route=product/product&path=43_7&product_id=108&car=43
cant find link for bottom one..
No your car was in the car park - nice paintwork - liking the orange
Cheers...maybe i need to go to specsavers lol
Have tou heard the full beans version jaimo ??on the monaro that is.
Must have left before I arrived
and neither of you showed... lol
As ever..work dependant.
2 wires from the bulb to the meter..
Live should have a switch in it to turn on and off..neutral straight to bulb
Sounds very simular to mine...done 7k so far with no issues.
New Owner Warning !
in Engine
Mdav that maybe trapped moisture..i once covered mine over winter...wont make that mistake again....moisture traps are best
