theduck
Everything posted by theduck
  1. Think im going to go that route as I don't think there is an off the shelf that will work. Problem with universal is that I can't find a suitable end for the pedal box so it means relying on me being able to fabricate something that will work in practice, as well as theory, to adapt the pedal box connection. My thoughts on this at the moment is a small piece of box section with a hole top and bottom, one to fit over the pedal connector and the other for the cable to pass through and then fit a solderless nipple on the end that will stop the cable coming back through. Having typed that out I'm now thinking one on the bottom and one on the side rather than top so it pulls in a horizontal motion and no vertical motion... Any thoughts anyone?
  2. I had an original sierra one, although needs replacing as poor condition, and the inner wasn't long enough, and I can't shorten the outer without cutting the captive end off the inner. Not sure why it is like this but possibly because of the way my pedal box has been positioned and/or the linkage i am using, I have seen a few pintos with a different linkage to the one I have which look as though they would require a shorter amount inner cable. Or maybe I am just making things awkward for myself?
  3. Ah ok, yes I have worked out a way to use a universal one with that type of end, which is looking likely. I have a suitable outer already so may buy a cycle brake line and a suitably sized nipple.
  4. Cycle brake cable is a good idea. Though im not sure what type of nipple you mean? Have you got a link?
  5. Haven't found one yet, CBS dont have any.
  6. I think I have solved my problem now anyway, but my pedals were mounted in same way as your old set.
  7. Thanks Mick. My main problem seems to be the inner not being long enough, I will measure how much inner I need showing and if someone could measure there's that would be great. Worst cones to the worst I will order a universal one and make something up to convert the pedal box end to take a solderless nipple.
  8. Was my first visit. Really enjoyed it and found people very welcoming, just needed to say hi!
  9. Vertical.
  10. Hi mick, not sure what pedal box, possibly the sierra donor(?) but it's a DGAV linkage on the carb.
  11. theduck
    Now Confused
    Not seen a roadrunner as yet. They are birmingham area aren't they?
  12. I need photos of how your drivers footwell looks, particular how the pedals and steering column are situated. Thanks on advance
  13. Did have a look on eBay and although there are ones with the right end for the throttle linkage on the carb but can't see anything suitable for the pedal box. May just Buy one of them and make up an adaptor.
  14. I knew I was missing a bit there. The inner on the one that came with the kit was too short also, not sure if that was wrong cable or something particular to my build.
  15. Soni had a throttle cable with my kit that fitted the throttle linkage and kind of fitted at the pedal box end, although it was loose and wold fall off. It's also in pretty poor condition so want to replace it. Problem is I can't find any that lOok the same as I have. My pedal box end has a ball type connector and the cable had a top hat type arrangement, although an open hoop may be a better option? After all that, what I want to know is what cable should I be buying?
  16. theduck
    Now Confused
    Personally I would buy an MNR as I feel they offer the highest quality product and can provide a totally comprehensive kit (just add fluids!) which is what I would want. The MNR chassis is all round tube and IMO the chassis looks better put together than other manufacturers. I saw some chassis' at autosport that had some very ugly looking welds on them
  17. theduck
    Gbs Zero St170
    Was talking to qwerty about this car today, can guarantee that having been mapped by TDF on their EC1 ecu that this will be a fantastic piece of kit. Matt at TDF has the Midas touch when it cones to engine control!
  18. theduck
    Rover V8 In S7?
    If a jag v12 fits, you can get pretty much anything in!
  19. theduck
    Wilwood Or Hispec
    You can get wilwood powerlite kits for £305 through locostbuilders. Not seen the hispec anywhere near that price b
  20. Just want to say thank you to mowerman for sending me instructions on the tie bar conversion, much appreciated!
  21. theduck
    Nintendo 64
    How many controllers?
  22. Be interested in your 13s if the price is right...
  23. Haha, yes I've had plenty of none starts!
  24. After replacing the VV carb with a weber 34 it was just ignition timing!
  25. It was steam. Its not being run again now until the coolant system is out on, had a lot Of difficulties with it so was run like that to make stripping it out easier if itbwas required, which it's not
