1,860 -
98
Posts posted by brumster
It's in the Helix catalogue... wait one...
<rummage down back of sofa....>
Hmmm ok their website link is dead but here's one from 2014, I doubt it's changed that much... from what I can gather, the Focus 1.8 clutch is a 220mm?
Cool, ok, so standard clutch then. So it looks to me like Helix do 2 uprated organic clutches in 220mm, one rated to 273ft.lb and one to 365... I suspect the former will suffice
No need for ceremetallc paddles, and keeps it relatively comfortable and driveable for the road, and you won't be ripping your flywheel to shreds in a few thousand miles... mind you, all depends how you drive and treat it of course
edit: One thing I will suggest - ring Anthony at Techcraft Motorsport (01926 403721), tell him I sent you his way, and explain your engine and the clutch, and he'll be able to advise you what's more cost effective, be it an AP or a Helix. I was going Helix on the Zero but he managed to get a better price on an AP clutch in the end... he knows his onions, I promise you.
So you want to go 4 paddle over a normal full-face clutch for serious motorsport use. They manage heat better but they don't wear anywhere near as well, and over time they take their toll on your flywheel. I'm not here to tell you why you want one, most people here make their mind up themselves, so I'll just tell it like it is. If Helix can't make you a conventional uprated clutch and cover plate for your engine, then you will indeed need to look into something more motorsport-oriented, but if you've got issues with torque overpowering your pressure plate, then there's nothing for it but a more heavily sprung cover - and with that comes the need for big thighs (or a hydraulic clutch of course)!
Sprung or solid centre? Well, solid will give you a more direct drive and if you like slipping the clutch to get the revs up on the exit of chicanes and so forth, then I'd recommend it, it's what I run in the rally car... but for a road car, I would say no, it 'aint for you. They are snatchy
. A sprung centre will take the stress off the cover plate, particularly if it's a conventional sprung type rather than a multi-plate style... which I presume you are avoiding.
Ultimately, why do you want a new clutch, is the current one slipping under full torque? What clutch is in it right now - size, type, material, spring strength?
If you've got known torque values then Helix can advise you of exactly the clutch you need
Solid centre you want to avoid, but you can still get sprung 4-paddles....
I would think since a narrowband is so limited in what it can tell the ECU, the ECU has to make pretty wild jumps either side of stoichiometric to "test the water" and figure out how much it needs to adjust by... it's a bit of a guessing game for the ECU, I believe, with narrowbands (fine for steady-state basic emmissions adjustment though)...
Most of the time, if you've had it tuned, the lambda will only adjust fuelling 1 or 2% off the base map anyway - I suspect the amount of fuel that's potentially saving is not worth fussing about.
I like to run one just so I know the state of my engine, to be honest. I use it to tune, but that's done now... but I see no reason to take it out. It's not adjusting fueling outside of 1%, but I can log to a laptop if I'm ever worried about it and take a look at how the engine is running (particularly if running a cat). A comfort thing really, but once you're mapped, it's probably not serving much purpose... I know what you mean, Longboarder.
Agreed, after reading that, if that's the legal position, I wouldn't be bothering (well, I wouldn't be bothering with a Lotus 7 and towing anyway, but, you know what I mean
Interesting challenge. Given the tank position, assuming you didn't want to interfere or change the tank at all, I think you're stuck with a rather low hitch height if you're picking up off the lower section of the chassis... I wonder if it would be too low? Obviously you could rise it up on the outside of the car, up at the back, but I wonder what strength/leverage stress this would put on the rest of the structure. I guess ultimately if you use thick enough steel, anything should be possible, but given the Zero rear end in the early days was known to fracture in places before GBS added webbing/strengthening, I'd be cautious about how much "safety margin" is in it, to be honest...!
Yes, I would suspect when they pull the car details up on the MOT database, the guidance will be shown on there...
The way it's modified, the easiest way is to mount it "sitting on top" of the battery tray, dropping down through the apertures that the monocoque car had for the pedals. If I recall, the back butts up against the original servo mounting plate. The pedals then hang down and, well, the rest is fairly obvious I guess. So the last picture would be as if you was looking from the right hand side of the car.
Throttle pedal mechanism can just be bolted onto the right hand side of it.
The 3D printed enclosures speak a bit "Arduino hacker" to me. I think all of these widband controllers are a bit of a muchness really. They all do very little for the money, I keep thinking I should make an open source one myself! But, time, as always...
Use a PLX myself. No issues. Had an Innovate LC-1 before (couple, in fact), not very reliable. LC-2 is probably better but I've decided to steer clear of them now.
Just a quick chase-up/bump on this. The gearbox is out and available, or otherwise will soon be going on eBay...
Got the old pedal box from the Exmo sitting here, surplus to requirements.
It's the underslung type, adjustable bias bar for the brakes, master cylinders included (0.625/0.7) and clutch pedal.
It has been modified as follows :
- Additional bracing (because, as it comes from OBP, it was bloody awful)
- Clutch return spring
- Mounting legs to sit on top of a monocoque bulkhead/scuttle (Exmo, and probably others)
- Tagged a brake light switch onto it
- Pedals bent to suit Robin Hood footwell
Takes the standard Sierra throttle pedal bolted onto the right hand side (I have it if you need it)
Originally fitted to the Exmo in order to ditch the servo and free up engine room for the engine conversion. Worked great with Sierra front disks and rear drums.
Open to sensible offers, I have to put a price so say £70 but try me....
Type 9 spline to Sierra diff flange fitting
875mm from tip to flange
Very little mileage, well under 1000 miles, good as new
As best as I can recall, this was the standard shaft we received for the Exmo but probably suits other models just as equally.
Open to sensible offers really... £25 plus the shipping, or collect?
I used a piece of flat 2mm steel welded, in a U shape, across the chassis tubes in the tunnel, that reached down and hovered above the propshaft/diff flange. Works OK for me up to about 90-100 then it gets a bit
Exmo was the same - a bent tube at the front strut top, that mounted the front of the wing, then lovely supplied roofing bolts
for the run down the side of the body, with a rubber trim strip in between. I saw many people added a second piece of narrow box-section tube half way down the wing to support it, but we never bothered and never had problems.
I actually quite like/prefer the swept wings from an aesthetic point of view.
I also am not entirely sure swept wings are IVA compliant, are they? I thought they didn't provide enough covering around the circumference of the front wheel and so failed? I thought that was why you never see them on a new build these days...?
edit: yup, see "wheel guards" section...
Mark makes on important point - that kit was developed and sold way before the modern IVA requirements and regulations. I don't know what parts you've got for it, or what you've been given with it to potentially fit, but I would take a good read of the IVA requirements document so that it's clear in your head what areas you will need to take care around. Exterior and interior protrusions are probably the worst of it. If you were given clamshell-type sweeping arches, for example, these fail to provide sufficient cover of the wheels for the IVA regs so you'll need to move to the cycle arches.
I wouldn't assume any part of it was done with the modern regulations in mind, so do your homework and get it right the first time (if the intention is to register it for on the road, of course)... there are some good articles on this site, if you register there's a complete build blog of my car in the Members Only section, with useful notes about the whole process of the build and IVA. Plenty of others too of course, out on the internet and so forth
That looks like a Cortina-based S7, so probably late 80's/early 90s?
The common lump to put in them was the Ford Pinto, yes, but in reality you can stick pretty much anything in it. Looks like you've got a Ford (Essex?) V6 in it at the moment - nice!
Chassis number might be on it, depends if the previous owner got that far, but probably not. You apply for one from the DVLA and then get it stamped into the chassis somewhere.
Not insane at all, I think that's a really cool thing to do for your son and his friends...
Not much, other than the price? Looks straight enough? Bit of a discrepency on engine size on the advert - 1796cc or 2 litre?
As Exmo's go, that looks really tidy to me?
edit: ooo, hold on, has he cut a load of metal out of the buttresses :-o ?
edit 2: he must have put something in there to strengthen that back out though, he must have done. Otherwise that front suspension would fold up on the first bump it hit! So maybe nothing to worry about, just check how he's put the strength back in. It says "engineer built" (that old chestnut) so fingers crossed it's probably be done very sensibly.
edit 3: rear wheels protruding from the arches?
True, and it is in line with the buildings that we saw getting ripped down at the weekend - they are all over that side of the site. So it makes sense. I guess I just figured even though the line ran through that section, there would be some "knock on effect" outside of that. I wonder if the use of the site will change to something more of an industrial estate, rather than a horticultural showground, as it seems to be going that way anyway... and it's not like our little kit car show needs all the space anyway...
Oh wow, sorry, I misunderstood. So Stoneleigh is staying as a functioning site?
I can imagine the agricultural show will do great with all those animals and a high speed train flying past every hour
Wow
what a shame....
So a question to all you wonderfully knowledgeable people out there...
Anyone know of a shaft (a driveshaft, or something materially the same in terms of strength) with a 30mm OD and a 36 spline end?
I'm only after an OE part that someone might be aware of, something readily available. I know plenty of places that will supply a custom shaft to any pattern I like, but before I get fleeced for a pretty sum, I'd rather see if there's a smarter way of doing this...
For clarity, I mean the spline fitting that the tripode fits onto - I'm not referring to a spline pattern into a gearbox or hub; it has to be just the shaft itself.
Yes. So you've got an in-tank pump already, do you know which one it is? That's not typical, so it looks like someone has probably retro-fitted it in the past, which means it's surprising it's not got a built-in "surge pot" (for want of another phrase). It might be that one is in there, but has become detached. Remove it and check, normally it's a plastic pot or curtain around the bottom of the pump pickup. If it's missing, or your pump simply never had one, then easiest thing to do is look to replace it with an in-tank pump that includes one. The Land Rover in-tank pump is the common recommendation on this forum, lots of the guys have gone that route. Hopefully with a bit of luck, the mount pattern for your existing in-tank pump is the same, or can be easily modifed to fit without having to remove and cut/modify the tank in any way.
Worst case, the next step is to leave the existing pump in place and fit all the gubbins related to a swirl-pot, which will necessitate another fuel pump, piping, filter and the swirl pot itself. Not ideal and a right ballache. Trust me, I know, I had to retrofit the same myself recently
but it's not impossible.
Swirl Pot In Fuel Tank Issues
in Mechanics
Yep, exactly, foam cubes made no difference for me.
Matt does have a point though, implying to a new visitor that fitting a land rover pump is a "cheap fix" at £35 might be hiding a lot of detail - work to modify the tank or have an adapter plate fabricated, and so forth... it depends on the car/tank of course. I'm not savvy with 2B petrol tanks.
