Help Needed Still No Power
Guest greavesy7
I was out driving and suddenly lost all the power from my pinto. There are no noises coming from the engine and I have checked the cylinder pressure and they are all good I have no idea what it is ???
  • Replies 30
I would check your fuel lines first, to make sure you at least have fuel getting through,
i had this and it was a non wented fuel cap that caused it.
Fuel line rubber pipes perishing and collapsing can do the same and preventing fuel getting through.
HTH
Guest greavesy7
I have checked cam timing
I'm running out of ideas
The fuel lines are new the only thing I can think it a blockage
Could a coil cause poor power
Guest sandy77uk
stripped and cleaned filters? are you getting a decent fuel pressure at the rail/carb?
Guest arf!!
always a first check is have you got a spark at the plugs, pull a plug out put the lead on it and hold it to an earth get a freind to crank the engine over while you check for a good blue spark, a yellow-ish spark points to a bad condensor, ? is it a pinto on standard electrics
Edited by arf!!
Guest greavesy7
it has an electronic ignition with bike carbs
Guest greavesy7
yeah ticks over fine but has no power and wont rev
Guest greavesy7
its an electronic one but im not sure which one it is
my moneys on fuelling
i'd check/replace the filters first, theyre only cheap so a good place to start.
i've known the metal pipe part on the sender be totally block full of cr@p before too, so might be worth take it out and seeing if there is any debris in there.
does your tank have a breather?
are you using the standard mechicanical pinto pump?
Guest greavesy7
my tank doesnt have a breather but i think the cap is vented
its running the bike fuel pump
if it was fueling surely the bowles wouldnt be filling and causing it to splutter
