Sierra Wiring Diagram / Haynes Manual
Does anybody have a Haynes manual with the wiring diagrams for the Sierra?
Or have any already scanned in/photocopies?
Mainly looking for the steering column/ignition switch diagrams....
Would be very grateful if anyone can scan in the diagrams to assist with the wiring loom of my build.
Thanks!
Thanks all.
I have a sierra steering column which has the wiring still attached. Not actually sure which loom these are from as it was purchased off eBay.
At worst, I can probably work out the wires by taking the stalk apart and tracing the wires to the components...
I plan to make my own loom up to use these wires in my build.
Cheers,
Guest robinj66
Look for markings on you the stalks - they will either start with 83, 87 or 90. 83 is the earlier pin configuration and 87/90 is the (same) later pin configuration.
Purely from memory, the 83 stalks had the horn as a stalk function (it was on the steering wheel centre for the later stalks).
I have this to offer. Think its for 87/89/90 switches.
Should add the colours are ford sierra loom colours so will match the tails on the plugs but probably not your aftermarket loom
