Failed Iva Southampton
Guest Jonnyround2003
1. Main lights have led not e approved
And rub on full lock
2. Front indicators 17mm to short
3 front wheel indicators stick out to much
4. Need to change exhaust clamp for one with out sharp edges
5. Need to prove age of engine for emissions test not sure how to get over this co to hight
6 . Rear hand brake cables fouling
7. Need radius on gauges have old smiths ones
Have to say the Iva man really helpful not bad for first attempt has been a long day
  • Replies 37
That is a nice "To do " list
One at a time stand back and make sure you have done what he wanted.
Next.......
and a PASS :clapping: :clapping: :clapping:
How did you guys get around the head lights catching on the front wheel arches I have a 2b thinking of getting smaller head lights
Guest ali2992
What were the handbrake cables fouling on? And what smiths gauges are you using?
If it's a wishbone 2b, try bending the headlight mounting plate upwards a little. It worked on mine due to standing on the plates before headlights were fitted.
HTH
Nick
They are old school guages with a sharp Stanford edge not rounded like the newer ones
Guest danny88
Have you got a ford pinto engine? If so write to ford technical with your engine number and they will give you the year of manufacture. Really nice guys and reply quickly too. Hope that helps
1 need to change - do you still have the RH ones -- the mounting stems will probably allow packing up with washers.
2 Extension tubes are the only answer if RH indicators used-- can't remember what we saw back in the summer.
3 Explain more
4 S/steel MILOR clamp is nicely rounded (spelling??)
5 Do you know engine number? Yes -- then Burtons catalogue gives all date codes -- was accepted for Florin.
6 Cable routes may be better if they cross over at tunnel -- gives more room.
7 Re-do dash covering with camping mat under to give the gauges a "frenched" look-- bezels should be too low to measure then.
HTH Jon, see you again some-time soon with a PASS
3 Explain more
Mikalor.
Guest aidankinnell
Southampton didn't accept the burton book when I Iva'd 18months ago, ford technical is the way forward.
Engine age codes are published in the Burton Performance catalogue and have been used at SVA & IVA for years
There are clamps you can buy on eBay to limit rack movement or you can use jubilee clips inside the rubber boots on the rack part
Like most things -- times change -- & the people that administer the rules.
