Failed Iva Southampton
Guest Jonnyround2003
Guest mdav1970
Jonny,
I posted a fix on here for the fogs when i did mine for the IVA last year, just put diodes in the power wires from the switch to main bean and dipped so the power couldnt feed back, worked a treat, i have some diodes left if you want a couple?
  • Replies 37
Ok great thanks anyone know where to get a catalytic converter from
the DOHC didn't have a cat AFAIK so should be tested for a co of 3.5 or better at idle but if you fit a cat it drops to 0.3 and has to be checked at fast idle as well as idle. Just weaken it off enough to get it through. If you can't do it yourself most garages will do it for you in a few minutes.
