Fog Light To Only Work On Dipped And Main Beam
Guest Jonnyround2003
Tried again this morning the brown white Collum link wire has power with ignition on and dipped beam then no power on full beam . I have a red white cable going to fog switch which is labeled lights and blue white cable labeled full beam I have figured how to get it to work on full beam now just need main beam to come on with fog ! So looks like I just need a feed from main beam supply but don't know which cable it is !
Spent a while on it again today worked out whats live and switch to just make the main beam come on ! How do I now get this to the fog light switch got it to work on full main beam just need main beam
Just read my Iva fail sheet RS4 :the rear fog lamp must only illuminate when dipped beam ,main beam or fog lamp are lit - It failed because rear fog lamp works on position lamps ? Don't understand why its failed !
Position lamps = side lights as said on fail sheet-- fog on only when dip or main ( head) lamps on.
