St170 Parts Needed
Anyone know where I can get engine mounts for ST170 engine in a Zero?
I think tractor modified his Zetec ones.
Yes got some spares but one side does need modifications yours for postage
Edited by tractor
Thanks Chris, how difficult are the mods?
Talk very very nice to him.
He just might even pre mod for you but not this weekend as I know he is not at home.
It is not difficult to mod just need to cut mounting plate off and weld knew one on probably about an hours work
Thanks Chris I will gladly take you up on your kind offer, hopefully you still have address from the water rail. If not please pm me. Thank you
hi mark these are the mounts its the one on the left that needs changing from the three bolt to a four bolt pattern DSC_0176_zpsvaun8euk.jpg
Edited by tractor
this is how it needs to be and is fitted directly below the water pumpDSC_0177_zpsxmsvjnzp.jpg
on mine I reused the wedge part of the pinto mount on the carb side and on the water pump side I just used the rubber mount straight to chassis plate
sorry for the delay but I have only just had the time to find them in the garage and I wont be able to get to post office till Monday
Excellent thank you please let me now how you want payment. A few more bits inlet manifold on order, exhaust manifold probably order direct from GBS, alternator kit and idler on order from retroford, the VVT from trigger wheels and I should be able to start the the exchange.
Thank you for your advice.
just a heads up there is a problem with the vvt software but Andi sorted it out for me
you have to disable something on your comp to get it to work
Edited by tractor
  • 5 weeks later...
Thanks Chris,
Will the engine run without VVT to check everything is working before buying the magic box?
