July 1, 201610 yr I have two gearboxes which need stripping, inspection and possible repairs, it will be mated to an ST170 engine. Which gearbox would select? Choices type 9 or MT75, I only want to pay for one.
July 1, 201610 yr type 9 is smaller, but mt75 will take more power (200bhp+). Type 9 has a removable bellhousing so if you for some reason decided to change to a different engine you could buy a bellhousing. most mt75 gearboxes have integral bellhousings although i think there are some which are separate. MT75 is probably lighter as its ally unlike the cast steel of the type 9, but i am not 100% sure on that. i like reverse being push down and up next to first on the type9. MT75 is more conventional with reverse opposite 5th.
July 1, 201610 yr Type 9. Easy to rebuild, can handle 200bhp no issues if the box was good to start with, upgrade it to the v6 spec and you get a decent 2nd gear + stronger bearings on the layshaft.
July 1, 201610 yr type 9 allllll day long I do have a v6 type 9 box that I will get round to fitting into my zero Edited July 1, 201610 yr by tractor
July 1, 201610 yr MT75 - because finding a good Type 9 to start with is getting more and more difficult.
July 1, 201610 yr MT 75. Type 9 only really good with straight cut noisy gears. If you like noise. Just to put a spanner in the works. Masada rd 5 or 6 speed. Another one good for 300 bhp. (alelegedly).
July 1, 201610 yr Can't comment on the MT 75 but the type 9 feels like a manful gearbox. A little bit slow and ponderous, with a weighty feel if using a shorter gear lever. If the rest of your setup is old school, why not keep it all old school? Having said that, a modern gearbox is easier and quicker in use with better parts availability.
July 1, 201610 yr I would base your choice on ratios. Type 9 with v6 cogs is good for 60mph+ in 2nd, rx8 box may be good for 300bhp but has really bad ratios its designed for a low torque high rev rotary. I looked at all the boxes and type 9 was the better bet with almost all parts still availble new. If you go type 9 i.d be happy to help you refurb it here...
July 2, 201610 yr Author Try the MT 75 first it is a good one why i kept it for 5+ years Stephen hi Stephen, Confident the gearbox is a good one, I am paranoid car has been on the road for 2 years and I have replaced the gearbox 3 times all type 9 with no history. So i decided which ever gearbox i use i am going to get refurbished, I want to enjoy the car i have missed to many weekends this year. Thought i might aswell upgrade the engine to ST170, which I was going to do over winter because the engine has to come out anyway.
July 2, 201610 yr Author I would base your choice on ratios. Type 9 with v6 cogs is good for 60mph+ in 2nd, rx8 box may be good for 300bhp but has really bad ratios its designed for a low torque high rev rotary. I looked at all the boxes and type 9 was the better bet with almost all parts still availble new. If you go type 9 i.d be happy to help you refurb it here...Thank Dan,Leaning towards MT75, but i have 2 knackered type 9's and they are becoming rare. How much to completely overhall?
July 2, 201610 yr Overhaul cost depends on what's needed, when you say knackered what's wrong ? Layshaft needles and syncho's are the usual suspects. You are looking hundreds if you want to replace all bearings seals gaskets and synchos
July 2, 201610 yr Author if you go for mt75 don't forget you will need a new propshaft More money, always more money.........I work hard earning it might as well enjoy it!
