Plenum For Sale
cb750
Plenum only, not the engine!
This is a cast alloy plenum with a 6mm adaptor plate that was fitted to a set of bike carbs that I had. I am told it is based on a modified Nissan GTIR plenum. There is no air filter supplied. Plenum is powder coated metallic red. Has some small marks on the coating. I have included the original adaptor plate for you to use as a pattern if you cut a new plate to suit your carbs. The plate was fitted to the carbs using longer bolts going into the carb bodies but I would change this to a thinner plate and use the carb intake air box rubbers to mount it (not supplied).
I believe one of the adaptor plate bolt holes has a partially stripped thread which won't be a problem if you make and fit your own plate, if not you will have to use a nut and longer bolt.
Approximate sizes:
Intake diameter - 80mm
Max length - 465mm
Max width - 173mm
Max height - 106mm including plate and gasket
Max height - 96mm without plate and gasket
Price £25 plus £9 postage Standard UK postcodes only, no islands and highlands.
Or can be collected from Aldridge West Midlands
Edited by cb750
