Top Wish Bone Ball Joint
Hi guys the season of good will is upon us , I HAVE A PROBLEM a bit like those jokes in a Christmas cracker you know when you think theres got to be an easy answer to this but i can't think of it right now .
as you may or may not know i'm putting together a super spec all seemed good and going quite well after a few set backs .............until today i came to fit the cycle wings and noticed the top ball joint (track rod end ) on the upper wish bone had some play in it
looking closer and after taking it off the thing that RH has cobbled together the nut is loose that holds it on , someone must have found a fix as its impossible to get a socket or spanner on the nut let alone turn it
cheers
Dave
Dave: Not really sure what you mean. We need a picture.
Also not sure what you mean by 'cobbled together', as the top ball joint is a standard Ford Transit Drag Link.
Thanks Al ill try and post a picture , but in the mean time , the top arm has a ball joint at the end the movable part of the joint dissapears through a hollow tube which in-turn is clamped with a pinch bolt in the stub axle inside the tube is the retaining nut for the ball joint welded at such an angle that makes it impossible to tighten
seen from the top its the thing the cycle wings are fixed to before the extensions are added
Dave
You need a thin wall socket --maybe 3/8" drive even then it's a very tight fit to get socket over nut.
your right thats what iv'e been using but even then i cant seen to get enough purchase on it to get it tight ,, was this really a standard ford arrangement ?
its so poor it looks like something someones made in their shed !! :crazy:
I had to cut a cheap socket down to fit mine
stephen
thanks mate looks like the answer
merry christmas
As above, I used a thinwall socket to tighten mine. Make sure that both tapers are clean and smooth with no burrs before tightening
Thanks to you all , just wanted to make sure there wasn't some other fix somebody had worked out before i destroyed a good socket
....... jobs done now the hammer i was using was several sizes to small !!!! Ho Ho Ho
