Pinto Injection Head
If you've got the head and carbs then all you need to buy is the cam and head gasket. My engine is as the post above but the head was skimmed to raise CR and a megajolt was fitted to fine tune the ignition. Gave 140 bhp at the flywheel on the rollers but more importantly to me is the loads of torque it produces.
If you choose to keep the injection the FR32 will NOT work well.
You need to fit a cam designed to use with injection.
Hi what cam would you recommend. Cheers. Dave
Look at NEWman cams with a good head job st2 made 145 from a 2.1 on 38 dgas and no silly break in effing about mick :crazy:
Good point, the standard efi doesn't like overlap.
The head job on mine inc equalised chambers , bronze guides ,ported to remove guide intrusion , an light skim ,10'5 cr with 1mm gasket ,torque by the shedfull and 145 at the crank :crazy: std valves 3 angle cut mick
Guest Bobbers
And still going well after two years abuse in my hands
Look after it ! I sweated blood and money over that engine!! :crazy: mick
There is a specific high torque cam for the Injection Pinto I think it is the FR34
A similar cam is the FR30 both have similar duration than standard just more lift and will not confuse the Fuel Injection system
Guest DAVE1954
Hi I think I'll just put 4-1 exhaust , and bike carbs( which I've already got) and see if I'll be happy with that, it is bound to be a fair bit off difference to my 1.6 . Thanks for all your help. Dave
Guest DAVE1954
Hi I'm going to fit bike carbs & 4-1 exhaust ( which I've already got) to the 2.0i , and see if I'm happy with it, i should see a big difference from the 1.6 thanks for all your help .
