Superspec Fuel Tank
deano266
my etb fuel gauge is miles out and its not worth using etb sender as fiesta sender incorperates the fuel pump im sorting mine out before summer, spiyda design make a fuel wizard www.spiyda.com also if not in a rush they will be at stoneleigh end of april
Maybe try to keep it in the club by checking out our own electronic wizard --- Simon -- AKA The Mad Professor -- he had a similar gismo in development.
The variable resistance in your tank will be a connection to the wiper contact ( central?) & to one end of the wire coil -- change the fixed contact to t'other end will at least have the gauge working correct way round instead of A about F. Then maybe an adjustment in arm length/attitude ( bend it ) will make in even more accurate.
I must be unique then in having a Superspec with correctly reading fuel gauge - shows full down to empty and is fairly linear. Not that I can take any credit. Must have been set up correctly by the previous owner.
