2L Blacktop Zetec Turbo
DeanRudkin
Guest lotusPaul
Just a very quick rough n ready calc on fuel.
Size of injector x amount of injector
6 (cc per bhp)
440 x 4 = 1760 ÷ 6 = 293.333 poential bhp.
Then x by duty cycle, average is 85% so 0.85. 249.33 potential bhp.
You can increase fuel pressure to give more flow, i can do re calcs for that.
But thats a close potential for working on.
Id like to see the dyno graph if you can post it.
Guest lotusPaul
I only ask because my calcs were based an AFR of 13. A cruise mode so to speak. Some ecu maps will give a richer mix under boost. I looked into this for you.
With all things being equal in the calcs that predict 233, increasing to the limit of 440cc injectors at an 85% duty gives fuel flow to support...300bhp.The magic 14.7 drops the power to 205bhp.
At the richer mixes your in danger of washing oil from the bores.
I know maths is maths but its how it drives that counts. Unless your leaning out at you current boost then why push for more.
