Sign in to follow this
preeday
Oil Filler Cap Pinto
I need a new oil filler cap, Would I benefit from putting an oil filler cap with the outlet on? & what do I do with the outlet? 2.0 pinto.
Share this post
Link to post
Is the outlet for a breather pipe? If you have an oil catch can you could connect it to that. If it is a breather then it will need to be connected to something or it will blow oily vapour around. Surprised one of the pinto boys haven't replied by now, God knows there are enough of them. If you haven't got a catch can and it works OK then why change.
Share this post
Link to post
There are 2 types of pinto oil cap, both are designed to allow the engine to breath
The first is this type, the engine vents from the underside of the mushroom
The second is this, that has a hose barb on it to allow you to route where the vapour goes, personally i'd put it to a catch can
Share this post
Link to post
I've got a mushroom cap on mine and I've had no issues, but I may just be simple.
Share this post
Link to post
Mushroom cap is fine, just means you might get a tiny bit of oil on your rocker cover
Share this post
Link to post
Reason I need a new one is cause I’ve lost my old one (don’t ask how)! A friend has an alloy one like this I can have -http://www.burtonpower.com/alloy-oil-filler-cap-breather-outlet-fp641.html
My old one was just a mushroom one, if I put the alloy one on what should I do with the outlet? Could I run a length of pipe & put a filter on the end?
Share this post
Link to post
you could leave it open, put a filter on it, put some pipe on it and route it to the floor, put a pipe on it and route it somewhere else with or without a filter, route it to a catch can. up to you really. A healthy pinto shouldnt breath much through there.
Share this post
Link to post
I’ve looked at catch cans, most have 2 outlets (or inlets), 1 goes to the filler cap but where does the other go?
Share this post
Link to post
On my xe one is for the pipe in and the top one has a breather on it. I don't have any oil vapour escaping now since I put a better quality breather on. Mine also has a drain fitting at the bottom but there has never been anything in it. If I was you I'd get the one with the outlet and put a pipe on and hang it down out of the way near the road. Most of what should come out of a healthy engine should be water vapour anyway. Cheapest, simplest option.
Share this post
Link to post
The pipe from my crank case breather goes to the inlet manifold, is this correct?
Share this post
Link to post
Assuming you have the standard carb arrangement yes, there is a little valve in the bit that plugs into the block so that the fumes only get sucked out when there is a vacuum in the manifold. You don't need a fancy catch tank, I use a bike drinks bottle with the cage, like many others.
Share this post
Link to post
Ive looked at catch cans, most have 2 outlets (or inlets), 1 goes to the filler cap but where does the other go?
The catch tank you want if you are going down that route is one that is baffled with 2 or more inlets and a seperate filter to let the tank breath
Share this post
Link to post
