Hi All,
I got my car through the IVA test a number of years ago, subsequently had a load of engine problems, which after a new carb, cam and starter motor and discovering a leaking inlet valve got it running properly. More months pass by and I finally ring my local garage to see if I can book an MOT, only to find out they don’t do MOT’s for Kit Cars. They suggested somewhere but I don’t really fancy driving the car over the hills to get there.
Does anyone know of an MOT station in the Macclesfield area that is experienced with kit cars?
Many Thanks
Have always found it's best to use the same station as does your daily driver, they had the work for the run of the mill wheels you own; so are probably prepared to go the extra mile.
Never heard an MOT station refusing to test a kit, they are just a normal Class 4 tests, the only time I have been an issue was when the tester was too large to fit in the kit 😂 he had the apprentice sit in the car.
I've never heard of that either. I have to stay with mine because my tester can't get in or out because of a bad hip but I'm quite happy to do that in case there is a problem which I can fix. Whatever next, no tests on red cars?
