short sump for 2L pinto would prefer steel one
Edited by max
Modified my sump then found after fitting it picked the oil up quicker than what it would return so had to have the crank ground and new bearings.
Then fitted the RS 2000/Mexico sump from Burton Power and new oil pump not had a problem since then.
Just had to file the baffle plate for the dip stick to line up correctly.
https://www.burtonpower.com/alloy-sump-pan-rs2000-rhd-with-baffle-plate-sohc-pinto-ft650.html
Alloy sump pan. RS2000/Mexico RHD with baffle plate Ford SOHC Pinto FT650FT650.jpg
Edited by maca
Text added
